It is currently Thu Nov 19, 2026 7:03 pm
 Post subject: MW3 Sig
PostPosted: Thu Apr 12, 2012 8:37 pm  (#1)
 Post subject: Re: MW3 Sig
PostPosted: Thu Apr 12, 2012 9:06 pm  (#2)
Good! Really good.
PostPosted: Thu Apr 12, 2012 9:32 pm  (#3)
I like that one! I can clearly see the focal, and even though it's not off-center as most people say it should be, it still looks good to me because of how the background and lettering is done.
PostPosted: Fri Apr 13, 2012 6:02 am  (#4)
Nice work. Good contrasts in there.
PostPosted: Fri Apr 13, 2012 11:50 am  (#5)
That is really good! I'm a MW3 player as well. I've played all the CoD franchise games with the exception of United Offensive.
Um .. were'd you get the solider from? Did you use a tut or on your own?
It'd be nice to use this one. This fellow is actually one of the guys that's in the same guild as I. It'd be cool to use him. That photo is bit on the intimidating side!
PostPosted: Fri Apr 13, 2012 12:08 pm  (#6)
Is it on this page? http://www.bing.com/images/search?q=mw3 ... sk=#x0y570
PostPosted: Fri Apr 13, 2012 6:17 pm  (#7)
I binged "MW3 Renders"
and i got that
PostPosted: Mon Apr 16, 2012 9:39 am  (#8)
and i got that
I wasn't 100% sure but I had a feeling I've seen that soldier before! That settles that!
I wonder what would happen if you took the soldier I posted applied some cartoonism to him and then warmed up the image a little bit? Hmmmm .. I might give that a try!
How did you do the background of the signature or at least point me to the source. I'm sure its pretty easy but I need something to follow! =(
PostPosted: Tue Apr 17, 2012 6:47 pm  (#9)
i smudged the render
Then i repeatedly overlaid a wall ( can't find stock )
then i did the same for the MW3 Stock
PostPosted: Fri May 04, 2012 6:06 pm  (#10)
War Hero wrote:
I smudged the render
WarHero .. Sorry it took so long to write back! Its been a rough couple of Weeks on the homestead!
Would you mind writing a really quick tut on this or point my to a tutorial that you followed. Just pretend I'm an idiot, which really isn't to far from the truth!
I got my soldier prepared, probably going to need to do more work on him once I get the back drop I'm place.
Thanks for your time and assistance!
cron
