It is currently Thu Nov 19, 2026 5:43 am
 Post subject: gif test page
PostPosted: Tue Aug 17, 2010 9:43 pm  (#1)
ok, tried to do an animation with no tuts, so I need this page to test it out.
I see lots of little foobars that I should fix, but I'm not going to, it's not that important.
 Post subject: Re: gif test page
PostPosted: Tue Aug 17, 2010 10:49 pm  (#2)
Looks like it works. =)
PostPosted: Wed Aug 18, 2010 10:10 am  (#3)
Looks good. The Droid font is cool. I see you double dotted the r in one of the frames. Good job! :-D
PostPosted: Wed Aug 18, 2010 10:13 pm  (#4)
Yeah, I like the droid font...tried adding dots elsewhere but decided to stick with only the r for now. I did get sort of mixed up between lower and upper case...I think I got it wrong on the h, lol. And yay, I got the gif animation to work correctly. I figure I need to learn how to do gif well before I try to move on to gap! Next thing I need to learn is how to do the fade into the next picture.
PostPosted: Fri Aug 20, 2010 8:50 pm  (#5)
Just add a sort of light grayish image (3 or so layers) in between each image animation. =)
The animation will play that grayish image for a second then switch to the next image.
If you want it to fade in like transparent to full opacity just create the first 6 or so layers going from transparent to full opacity, then fade out the opposite..fade into the next image the same way. =)
Or you can fade in with the first image and fade in with the second...fade in with the third..so on and so on...
this way you need not create more layers for the fade out causing bigger file size.You want to keep it small as possible.
PostPosted: Sat Aug 21, 2010 5:04 pm  (#6)
I thought that might be the way, but haven't had time to try it yet. Got the grandkids over, and they have been hogging the computer. At least they brought the macbook for me to play with, but since we don't have a wireless router, and I don't know the neighbors password, I can't get online with it, lol.
