It is currently Thu Nov 19, 2026 7:04 pm
 Post subject: We keep a eye on you
PostPosted: Tue May 01, 2012 9:04 am  (#1)
Take care, don't stare the globe or the Globe will start staring at you :wh
The Gimp post work here was very simple :i just selected by the ... floor that was of a too light blue, and darkened it, for a darker atmosphere and to make pop out more the object.
Simple but did a difference
 Post subject: Re: We keep a eye on you
PostPosted: Tue May 01, 2012 9:09 am  (#2)
love it PC, especially the first one. great
PostPosted: Tue May 01, 2012 9:46 am  (#3)
Thanks molly glad you like
PostPosted: Tue May 01, 2012 9:55 am  (#4)
They're beautiful PC.
PostPosted: Tue May 01, 2012 10:27 am  (#5)
Thanks Erisian, on that kind of objects (spheres, ellipsoids ) maps on the normals work really well
A pity that , even when map are seamless, there are visible seams (in this case too were seams but i rotated the map till they went out of view, in the backside )
PS a linguistic problem , dictionary doesn't help much:
what the exact meaning of "normals" in 3d programs ?
PostPosted: Tue May 01, 2012 11:14 am  (#6)
To the best of my understanding, a Normal is the surface of a bump that is parallel to the object on which the bump appears and perpendicular to the bump itself. If you were looking down on a pyramid with a flat top, the flat top would be the Normal.
PostPosted: Tue May 01, 2012 11:53 am  (#7)
Funny thing, normal also refers to parallel in mathematics too. I guess since fractals are math in art it only makes since. Sorry to intrude.
PostPosted: Tue May 01, 2012 12:02 pm  (#8)
No problem Zward. Normals in 3D art are referring to texture.
PostPosted: Tue May 01, 2012 12:04 pm  (#9)
Ah I see, was just curious if there was any relation to the mathematics side of it because fractals are nothing more than mathematical formulas, are they not?
EDIT:
Completely scratch out what I said! Normal is perpendicular to the plane of reference. My Bad.
PostPosted: Tue May 01, 2012 12:06 pm  (#10)
Yep. It's complex maths. However, the term "Normals" is used in all 3D sculpting, not just 3D fractals.
PostPosted: Tue May 01, 2012 12:07 pm  (#11)
Now if you can make this and animated blink PC. Still very cool. :)
PostPosted: Tue May 01, 2012 11:23 pm  (#12)
Thanks Erisian your graphic explain well (instead the dictionary described normal just as ..the opposite of weird! )
@ Lyleyk
nice idea not sure how to do but may be interesting to try
