It is currently Thu Nov 19, 2026 7:05 pm
 Post subject: Look Closer
PostPosted: Sun May 06, 2012 1:16 am  (#1)
A quiet forest scene illustration for some chapter in book II. Mara, the protagonist, learns to converse with the trees.
This is the finished version of the WIP that is already a couple of weeks old (this took me longer than I thought it would) viewtopic.php?f=11&t=4152
Image is link to bigger version. Can you find all the faces?
 Post subject: Re: Look Closer
PostPosted: Sun May 06, 2012 1:33 am  (#2)
Very cool! Can't say I found all the faces; the trees were alive from what I could see.
PostPosted: Sun May 06, 2012 3:16 am  (#3)
Very nice, I saw three faces but I am sure there are more. great work merrak
PostPosted: Sun May 06, 2012 4:31 am  (#4)
The background is just amazing,
maybe there is something strange in the girl anatomy, more exactly in the way she move :
her right side is perfect but there is something wrong in the left side of her body (or maybe in her cloth, still only in the left side)
I really cannot focus exactly what i found wrong there, still i feel something that doesn't fit well
But that may be a problem with quite good images as this, a detail a bit more weak that in less good artworks would be unnoticed may pop out more
because everything else is very good and so the contrast become more strong
PostPosted: Sun May 06, 2012 4:40 am  (#5)
Maybe it's because there appears to be another light source to the left and behind the girl. The rocks on the right also look as if there is a light source to the left. Love the artwork.
PostPosted: Sun May 06, 2012 9:22 am  (#6)
I found 9 faces. :)
PostPosted: Sun May 06, 2012 9:36 am  (#7)
Yes, that especially on the left leg... but also,even more ,the cloth:
looking again the cloth outline on the left is almost a perfect straight line, opposite to a more natural shape on the right side
Anyway, again is a quite good work
PostPosted: Sun May 06, 2012 9:39 am  (#8)
Excellent work. I love your style.
PostPosted: Tue May 08, 2012 10:47 am  (#9)
@Odinbc, @Molly
There are 39 faces (see the sign posted on the tree - the paint is dark, but it gives the tally)
Glad you liked the background :) After not having seen the image for a couple days I would agree with you. I'm not sure what is wrong either. The way her hips are positioned seems to just result in the cloth falling that way - but perhaps it doesn't look curved enough. In any case, Griatch (in another thread) gave a good argument for why that may not even be the best pose, technicalities aside. I would be more inclined to redo Mara entirely (which wouldn't be too hard as she is on a separate layer) instead of fixing this version.
Thanks for the comments! There are two intended light sources - the end of the forest, and the beams up and to the left, through the trees.
I found 9 faces. :)
24 to go!
Thanks!
PostPosted: Tue May 08, 2012 11:14 am  (#10)
I see the sign now. I just ignored that while looking before, I didn't know what it was. Yes I do see lots more faces now but would take forever to find 39.
Anyway, very well done and yes, I see where the girl could use some fixing. When I first looked at it, I thought she was facing out cuz of her knees but had to focus a while to make it look right. The different light directions were playing tricks.
Super job on the painting.
PostPosted: Tue May 08, 2012 4:45 pm  (#11)
She is supposed to be looking up into the light. I think one problem is she has so much hair that the viewer can't really see her nose - so it looks like she is just staring straight forward. I think I may redraw her walking the other way (toward you) so that her face can be seen. Originally I wanted her walking into the light - but now I don't remember why, and it probably sends the wrong message.
