It is currently Thu Nov 19, 2026 8:13 pm
 Post subject: Rockflakes render and pattern (SEVERE DIAL UP WARNING !!)
PostPosted: Thu May 17, 2012 5:27 am  (#1)
So much photo, illustration ,articles and even video on the delicate snowflakes patterns, and almost nothing on rockflakes even if are less fragile and maybe even more fascinating..
So here some exclusive images of rockflakes (on transparency )
EDIT: are png, to preserve transparency,all at least at 1600x1200 so page may take a bit to load even on broadband and almost forever for dial up...but when loaded you get higher quality possible )
and thinking to Leylejk why not a rockflake pattern..ooppss iGC would not accept the pattern size, scaling down to fit below 5mb
yes ,done
 Post subject: Re: Rockflakes render and pattern
PostPosted: Thu May 17, 2012 5:42 am  (#2)
oooooooo. Nice pattern PC! :bigthup
PostPosted: Thu May 17, 2012 6:16 am  (#3)
Glad you like Drac
As snowflakes also rockflakes tend to melt when they hit the ground as here..
But back to renders and patterns
this is seamless and contains also 4 cool frames
and a few objects a triangle
a rectangle
a rhombus
another rockflake
Decorative borders
Till now all seamless, to end something raw and less symmetrical
That reveal also the origin of this series, a series of M3D renders, that come out interesting but not too original
i used gimp to first cut out the original BG (using the z-buffer, a sort of depth map that M3D may automatically create, often very handy to cut out the bg cleanly)
Then Gmic to morph, more exactly mirror (and would be a lot more to explore , i am sure i can make very nice globes , cubes and ellisoids from there
i selected the most interesting renders, but i have more , if you think interesting or useful just ask i may add more
 Post subject: Re: Rockflakes render and pattern (SEVERE DIAL UP WARNING !!)
PostPosted: Thu May 17, 2012 7:12 am  (#4)
Your renders are getting wonderful and stranger every time PC. Not sure if you know of Schmiegal or not (see deviant below) but you both do wonderful 3D like renders. :)
http://schmiegel.deviantart.com/
addendum: I see you already posted at his blog PC. lol
PostPosted: Thu May 17, 2012 7:18 am  (#5)
and putting a few of that together, offsetting the layers to make symmetries less obvious, and adding a new bg
Climbing El Dorado
that i suppose is a fake M3D since most of effect were assembled in gimp (using that semi-transparent layers i did show before )
PS Lylejk
yes i do know Schmiegal i like your images (and his filters for pixelbenders ) is one of my contact on flickr and DA
PostPosted: Thu May 17, 2012 7:43 am  (#6)
OOPPSS , looking better the placement of that last BG sucks, i quickly corrected
PostPosted: Thu May 17, 2012 8:21 pm  (#7)
your work inspires me to start doing it again.
PostPosted: Thu May 17, 2012 8:45 pm  (#8)
This is my first one in several months, i forgot how much fun it can be.
