It is currently Thu Nov 19, 2026 8:55 pm
 Post subject: When the Orbital Peeper got too close the Hive went scuba
PostPosted: Sun May 20, 2012 6:12 pm  (#1)
The Hive...
And following the scuba excursion of the Hive
someone says that the fractal went scuba to avoid the glance of the...
...Orbital Peeper
 Post subject: Re: When the Orbital Peeper got too close the Hive went scuba
PostPosted: Sun May 20, 2012 6:14 pm  (#2)
Wow! You just keep getting better. I love all of those.
PostPosted: Sun May 20, 2012 6:18 pm  (#3)
actually are 4 but 2 links were broken...fixed now
PostPosted: Sun May 20, 2012 6:19 pm  (#4)
I edited my post accordingly. Thank you.
PostPosted: Sun May 20, 2012 6:23 pm  (#5)
and very glad you like.
honestly still i have a lot to learn but i can't stop to play with it
the first 3 so including the first are raw fractal but with a trick..basically each come from the combination of 2 different fractal, one loaded as bg image
hu you are so quickly to reply! :ninja
i was editing to add my thank for the comment but you was faster
PostPosted: Sun May 20, 2012 9:08 pm  (#6)
Those 3D images are so fascinating...I want to be able to go inside them and explore them more!
PostPosted: Sun May 20, 2012 9:10 pm  (#7)
I know, they are all just jaw dropping
PostPosted: Sun May 20, 2012 10:00 pm  (#8)
More crazy wonderful stuff PC; I watch Ancient Aliens on H2 and now getting to wonder if some higher intellence is influencing your behavior. lol
PostPosted: Sun May 20, 2012 11:56 pm  (#9)
Higher Intelligences...no it was just that weird rock
i was stumbling in the Desert,not sure why because was a bit too sunny ,hot and dry and i was feeling weird, sort of stoned..
So stoned that not only i could not remember why i was there but i didn't even noticed the only damned Stone of
of that bloody desert...a damned big rocky thingy, at least 15 meters tall
and i didn't saw till i smashed my head against! :gaah
i few hours later i woke up, and i even took a photo of the stone
...it was a good idea because after was impossible trace the stone back ...strange that could be so difficult find a 15 meters tall rock in a totally flat desert, but i remember well that was a rational explication for that too
As that of my doctor he says that my interest and even understanding of complex geometries and fractal has a rational explication, the trauma indirectly stimulated the pineal gland that indirectly stimulated some neurons..
there is always a rational explication, as always repeat to all the superstitious people that sustain that there is a Monolith, at least 15 meters high that keep following me with the maximum nonchalance , floating behind me at few centimeters above ground when i walk, and acting as was a normal innocent rock, there from always, when i sit or stand still
it was very embarrassing in the Barber Shop, the barber was insisting that no 15 meters high Monoliths were in his shop before i got in
But i tell him that he was just having hallucinations
how a 15 meters Monolith could fit inside his barber shop with the ceiling at less than 4 meters ?
So i tell him that was clearly wrong , was nothing to worry except his Hallucinations.. he should just kept calm and relax, breath deeply ...
He become sort of nervous, then red ,very red,more and more red, than red shifted to violet then to bluish, and mumbled something as "my heart...my heart" ... i suppose a last poesy for his beloved, but the poor man died before could find a rime for "heart", and left his poem unfinished
the Monolith remained stuck there , because too high to get out and later was rationally classified as a consequence of local Volcanic activity ... so finally i was free from my Hallucination
But i had to change Barber , it seems the poor Barber hallucinations were caused by the incoming heart attack, but the Shop is still closed because with that Volcanic stone stuck in the middle of the Shop there is no sufficient space left
PostPosted: Sun May 20, 2012 11:58 pm  (#10)
James Joyce would like to have met you PC. lol
PostPosted: Mon May 21, 2012 9:52 am  (#11)
Get Mandelbulb 3D and you can. You can even animate your exploration.
PostPosted: Mon May 21, 2012 2:42 pm  (#12)
that is exactly how i started,,. i copy the code that was included in the image comment (as often for M3D image ) clicked the apppite "paste text " button and perfectly recreated that fantastic fractal i saw on DA
and from there i start to move, first putting more light on with various angles and colors to see what already there , then changing lens ( for M3D changing FOV, zooming in and out and then finally i started to move searching unexplored corner,
This is a kind of tweak that don't require technical knowledge but may be rewarding
the "formula" was just literally the key to enter in a 3d word,,,at soon you enter your position field of view are identical to that still image but if his Autor looked to the right , you may instead look what at the left, or behind a corner...walk closer and change light and colors.
of this there is a sort of preview, no perfect but usually sufficently close
