It is currently Thu Nov 19, 2026 8:12 pm
 Post subject: Ghost Diagrams - Ball in a Wall
PostPosted: Fri Jun 01, 2012 5:51 am  (#1)
 Post subject: Re: Ghost Diagrams - Ball in a Wall
PostPosted: Fri Jun 01, 2012 6:53 am  (#2)
I do this a lot with fractals - it's great fun.I usually duplicate the ball at different sizes and spread them around a bit.
PostPosted: Fri Jun 01, 2012 7:19 am  (#3)
While i was figuring out a bat file to run Ghost through Shellout i thought what the heck i may as well create something while i am here. :lol
Here is one i made a while back, about 2 years ago i think it was.
PostPosted: Fri Jun 01, 2012 8:29 am  (#4)
Reminds me of the 70s,which I made every effort to get out of.
PostPosted: Fri Jun 01, 2012 4:04 pm  (#5)
the first look more as a semi-sphere (that is still a cool effect) i think depend from the shadow
I really like the second too
PostPosted: Fri Jun 01, 2012 5:04 pm  (#6)
That is the exact effect i was trying to establish PC! A ball stuck halfway through the wall.Or half a sphere.
Hence the topic title "Ball in a Wall" :)
I probably should have made the shadow surround the ball more for more of an impact effect though.Maybe darker also. Thanks for the kind comments.
But then it would be called "Balls in the Wall" :P
Great idea though!
I was born in 1963 so right about 1970 i was age 7 so there was no escaping it for me. :lol
It does sort of have those hip colors though! :hehe
PostPosted: Sat Jun 02, 2012 12:58 pm  (#7)
Here's an animated fractal ball.
PostPosted: Sat Jun 02, 2012 3:28 pm  (#8)
pretty.
PostPosted: Sat Jun 02, 2012 4:41 pm  (#9)
Oh wow Erisian that is soooo cool. I am all about animations. That must be a lot of work it has 30 Frames. You are deadly... a superior artist with animations skills.
I like without the background too.
Oops. I see the white line showing on the image above. I just did a quick background removal but this one I cropped the background out.
PostPosted: Sat Jun 02, 2012 4:45 pm  (#10)
Thank you Barbie. It's actually very easy if you follow the spinning pole tutorial but map to sphere rather than cylinder. It does look good without the background as well.
http://www.gimpchat.com/viewtopic.php?f=23&t=2255
PostPosted: Sat Jun 02, 2012 4:46 pm  (#11)
That is nice Barbie, what is causing the white seam on the side I wonder.
PostPosted: Sat Jun 02, 2012 5:13 pm  (#12)
That's better. Looks good.
PostPosted: Sat Jun 02, 2012 5:21 pm  (#13)
Yeah... I noticed that too as soon as I posted it. I just did a quick removal of the first Frame to remove the background. But then re-did it properly by cutting out the background on all frames with circular select.
PostPosted: Sat Jun 02, 2012 7:36 pm  (#14)
Thought I'd play a bit with this. There's some distortion for some reason but I'm having lots of fun with it.
PostPosted: Mon Jun 04, 2012 8:24 pm  (#15)
That is so cool Erisian !
You didn't just make the ball touch the left/right sides but you actually made it more convincing with the "distorted stretching detail" of the ball to create the bouncing off the walls effect. (moreso on the rightside).
PostPosted: Tue Jun 05, 2012 5:44 am  (#16)
I hope this not too off topic, i didn't use ghost diagrams for those but the idea to use the same image for sphere and bg is the same
(click to enlarge )
She Breaks My Heart by PhotoComiX, on Flickr
Xspheric Xmas gift 2 by PhotoComiX, on Flickr
same but with rhombus
Shape by PhotoComiX, on Flickr
back to sphere
Just a Drop ? by PhotoComiX, on Flickr
a dice with rounded corners would be OT ? (if you click for the original size, you get on a transparent BG )
rhombus by PhotoComiX, on Flickr
(i may explain how i did the dice in MM using sphere and rectangle2ellipsoid )
with different texture (btw ,my texture )
Spheric by PhotoComiX, on Flickr
Mimetic Rolls by PhotoComiX, on Flickr
Same concept but with photographic background
Fairy's Castle by PhotoComiX, on Flickr
or psychedelic BG ?
Fractal Tunnel with sphere by PhotoComiX, on Flickr
animated
i could not find the ping pong version of this
i believe nobody else used this effect yet
hem..sorry for the flood but i think could be interesting as overview of possible effects
PostPosted: Tue Jun 05, 2012 6:07 am  (#17)
i tried to resist but i can't left those out, i like them too much
A Sphere in the Darkness (Vintage version) by PhotoComiX, on Flickr
Ancient Village, ancient Sourcery by PhotoComiX, on Flickr
PostPosted: Tue Jun 05, 2012 10:43 am  (#18)
PhotoComix - you're unbelievable!!! Those are beautiful! :hi5 :jumpclap :clap
Barbie - the distortion was unintentional. I've no idea what caused it but thank you anyway. :)
PostPosted: Tue Jun 05, 2012 11:49 am  (#19)
Bouncing balls has always been fun!
PostPosted: Tue Jun 05, 2012 3:28 pm  (#20)
Since everyone else is playing with their balls
