It is currently Thu Nov 19, 2026 8:09 pm
 Post subject: MathMap-Redfield-Droste
PostPosted: Fri Jun 01, 2012 8:38 pm  (#1)
 Post subject: Re: MathMap-Redfield-Droste
PostPosted: Fri Jun 01, 2012 10:17 pm  (#2)
What's a Redfield-Droste Rod? While we are on the subject, I noticed this program (http://sourceforge.net/projects/drdroste/) at Sourceforge, but it's either buggy or I'm too dumb to figure out how to use it. lol
PostPosted: Fri Jun 01, 2012 11:17 pm  (#3)
Well i used mathMap Droste and Redfields lattice, also map to gradient (my steel Cable Gradient)
I took a white image
I opened Redfields Lattice program
I created a lattice i liked
Then i ran that through MathMap Droste
After that gradient map.
Thanks for the link Lyle. :)
Here is how the program works Lyle
You select an image and then use your mouse to select a Droste area.
click the number spirals
The sliders work like this
Max Recursion - recurrence of the image downward
Alpha Filter - takes out those overlap lines when spirals overlap
Rotate - rotates the entire image effect.
Check out this example chart
My results from those settings
Cool program and i bet it can do some phenomenal things once you get the hang of it. :)
Great find Lyle!
PostPosted: Fri Jun 01, 2012 11:26 pm  (#4)
Where you show arrows in the navigation area, I had blank squares (ran it in Win7). Might be a Win7 incompatibility issue. Very familiar with Redfield's Lattice plugin by the way (now that I know what you meant by Redfield; lol). :)
PostPosted: Fri Jun 01, 2012 11:31 pm  (#5)
Yeah i didn't know what to name it :lol
Do the buttons still push or work for you?
PostPosted: Fri Jun 01, 2012 11:35 pm  (#6)
I deleted the program but yes; blindly was able to push buttons but it was the ignorant leading the blind and my result sucked so thought, well, it is sort of beta so deleted the program. lol
