It is currently Thu Nov 19, 2026 8:12 pm
 Post subject: Egyptian neck wear?
PostPosted: Thu Jun 07, 2012 9:50 am  (#1)
Or possibly wings. :)
Vector Paths 2 Beta. :) :bigthup
B and P this plug-in is outstanding!
 Post subject: Re: Egyptian neck wear?
PostPosted: Thu Jun 07, 2012 10:43 am  (#2)
That's beautiful Rod. I'm jealous - I can't work out how to use the plugin.
PostPosted: Thu Jun 07, 2012 12:27 pm  (#3)
Me either, it seems to be only for smart people.
PostPosted: Thu Jun 07, 2012 1:23 pm  (#4)
Looks cool Rod; too lazy to play today (even lazier then usual). Might just wait until B&P releases this one anyway. :)
PostPosted: Thu Jun 07, 2012 1:27 pm  (#5)
Did you look at these examples?
Vector Path 2 Gimp Plug examples.pdf.7z [449.02 KiB]
Downloaded 106 times
PostPosted: Thu Jun 07, 2012 6:17 pm  (#6)
Yes just take a look at the PDF included and you can kind of get a picture on how it works.Also just playing around with the settings and watching what happens helps a lot.
X and Y rotation works as if you are moving the center rotation point (X = left or right) (Y= up or down)
Rotation angle is the direction amount of the rotation (left or right)
Same with the beginning of each formula - If you place a number with a + or - sign after, you move the entire path on the image window. For instance if i wanted to center the ENTIRE path in the horizontal i would use 75+ at the beginning of the X formula.Or whatever number centers the path. If you make a mistake on the formula input fields the plug in will let you know it. :) - Another nice feature about the plug-in.
Plus many more available features for tweaking the path.
If you want a more even path look try either adding a few more points or subtracting some.
I was able to get an exact look on each end of a path by doing just that.
Just play with it for a bit and you will get pretty comfortable with the settings.
