It is currently Thu Nov 19, 2026 8:09 pm
 Post subject: New MM filter test : rounded rhombus
PostPosted: Sun Jun 24, 2012 1:17 pm  (#1)
Just a quick experiment to create and test a new filter for MM...and believe me was really easy no knowledge of code required
Original image : Gardens_11___Stock by Inadesign_Stock (on DA )
posting now the code on viewtopic.php?f=9&t=4566
EDIT i just made a animated version too...i saved the test as swf (flash) but the file is about 67 MB not sure how to display here
anyway seems cool i am posting the code now on the linked topic
 Post subject: Re: New MM filter test : rounded rhombus
PostPosted: Sun Jun 24, 2012 2:24 pm  (#2)
Cool effect! I'm working on a new filter just to the learn the scripting language - trying to post details..
PostPosted: Sun Jun 24, 2012 2:39 pm  (#3)
i just saw your message i believe you are using Mathlab, this is Mathmap
how you could run Mathlab filter in gimp ? Gimp may accept a lot of different languages but i didn't know that mathlab could be supported
PostPosted: Sun Jun 24, 2012 3:30 pm  (#4)
Sorry my bad, meant Mathmap. Been Googling the hell out of Mathmap in the last couple of days trying to scrape round for as much information on it as I could get. Had Google tell me it thinks I'm looking for Mathlab so many times I think it must have stuck!
Thanks for pointing it out, I've corrected my posts.
PostPosted: Sun Jun 24, 2012 9:29 pm  (#5)
You already know the main MM side, you may get some more info on the MM group on flickr (almost dead now but still there are the old post) and on the MM group on google.
