It is currently Thu Nov 19, 2026 8:12 pm
 Post subject: New MathMap filters test : Galactic Twist (animated)
PostPosted: Mon Jun 25, 2012 7:07 am  (#1)
it is really fun assemble new filters with the Composer this is...Galactic Twist :yes
the video last only 5 seconds (i have no more hosting space on vimeo so i could not make longer ) but show well a possible effect. :geek
it is based on Nathan De Gargoyle "Twist" and Rectangle2Ellipsoid (humm..thinking now i did not a confront with the effect of the original Twist :hoh but i believe is even more twisted..
EDIT
no video but a gif...because the effect require the Combine animation mode that is easily available for gif but that i have no idea how to get for video file :gaah
sorry if would take time to load
 Post subject: Re: New MathMap filters test : Galactic Twist (animated)
PostPosted: Mon Jun 25, 2012 7:31 am  (#2)
Cool twist
PostPosted: Mon Jun 25, 2012 2:55 pm  (#3)
That's pretty cool PC :)
Did you copy the filter code?
PostPosted: Mon Jun 25, 2012 5:51 pm  (#4)
yes i saved the combination (very simple "animated rect2 ellipse " + enhanced pond ) and also the code but i am not sure if the effect is really different from enhanced pond alone i should do a confront face by face
also i want see if there is a way to offset the effect...as now is centered in the very center of the image and that is a bit limiting.
