It is currently Thu Nov 19, 2026 8:14 pm
 Post subject: Sunset
PostPosted: Wed Jun 27, 2012 6:24 am  (#1)
Thought I'd try a landscape for a change.
 Post subject: Re: Sunset
PostPosted: Wed Jun 27, 2012 6:26 am  (#2)
very pretty eris. Love the purples, very nice job on the grass.
PostPosted: Wed Jun 27, 2012 6:28 am  (#3)
Thank you Molly. The grass was made easier by GPS nature effects. You still have to work with it but at least you're not painting every blade individually.
PostPosted: Wed Jun 27, 2012 6:29 am  (#4)
Definitely like this result Erisian. :)
PostPosted: Wed Jun 27, 2012 6:31 am  (#5)
Thank you Lyle. :)
PostPosted: Wed Jun 27, 2012 11:31 am  (#6)
Very nice! It reminds me of some of the sunsets in western Washington state. Good job on the reflection, too.
I do feel, though, the horizon isn't very well defined. The water and sky seem to blend together.
PostPosted: Wed Jun 27, 2012 11:36 am  (#7)
Thank you. I wasn't sure whether the horizon should be defined or not because of the glare of the sun. The reflections were easy. Having painted them "straight" I ran water-reflection.map scm and used it to displace them. (Ain't I a cheat?)
