It is currently Thu Nov 19, 2026 9:36 pm
Post new topic Reply to topic  [ 47 posts ]  Go to page 1, 2, 3  Next
 Post subject: Enhanced pond discs
PostPosted: Sun Jul 08, 2012 6:11 pm  (#1)
Having filled a circular selection with a metallic gradient, I ran selection bevel on it then repeatedly shrank the selection and repeated selection bevel. Afterwards I played with MathMap/distorts/enhanced pond followed by G'MIC thin brush smoothing. Enhanced pond gives some incredible design shapes.
This was an earlier one that I drosted.
 Post subject: Re: Enhanced pond discs
PostPosted: Sun Jul 08, 2012 6:26 pm  (#2)
I really like the top one cuz I love shiny. nice job
PostPosted: Sun Jul 08, 2012 6:27 pm  (#3)
Thank you Molly. I'm a big fan of shiny too.
PostPosted: Sun Jul 08, 2012 8:46 pm  (#4)
Going to have to play with enhanced pond since it did give a cool reflective quality to your disk Erisian. And you just know how much I like the droste result too. ;)
PostPosted: Sun Jul 08, 2012 10:11 pm  (#5)
both cool
@L
it is me or gmic droste is very different from the mathmap one ?
i just get effect of double mirror and works only with rectangular images (MM droste would work with any other shapes )
PostPosted: Mon Jul 09, 2012 12:22 am  (#6)
Yeah; G'MIC droste gives you the classic square result whereas Mathmap's Droste defaults to the spiral. Both are droste though; just different result. You can sort of mimic the spiral in G'MIC by using the angle slider and stuff, but it's a lot of work. :)
PostPosted: Mon Jul 09, 2012 4:07 am  (#7)
Thank you both for your comments. Glad you like them. :)
PostPosted: Mon Jul 09, 2012 4:40 am  (#8)
These three
Were all made from this one
PostPosted: Mon Jul 09, 2012 6:26 am  (#9)
From a simple embossed cross.
PostPosted: Mon Jul 09, 2012 6:55 am  (#10)
Like a pushbutton.
The embossed crosses are beautiful jewelry pieces Erisian.
PostPosted: Mon Jul 09, 2012 8:11 am  (#11)
Thank you Barbie. I like the animation - I might have a use for that idea. :)
PostPosted: Mon Jul 09, 2012 9:07 am  (#12)
Thank you for the jewelry idea Barbie. Molly would have done a better job of it though. :) :pengy
PostPosted: Mon Jul 09, 2012 10:09 am  (#13)
A six pointed star
And a layered disc
PostPosted: Mon Jul 09, 2012 11:34 am  (#14)
Those 6 pointed stars are great aris. woo hoo.
PostPosted: Mon Jul 09, 2012 11:55 am  (#15)
Thank you. It's so easy - just create any shape you like then play with Enhanced Pond.
PostPosted: Mon Jul 09, 2012 11:56 am  (#16)
I have never used that. Is it in GMIC?
PostPosted: Mon Jul 09, 2012 11:57 am  (#17)
It's in Mathmap/Distorts.
PostPosted: Mon Jul 09, 2012 1:46 pm  (#18)
... and could be animated ( from the setting tab...from there you may even preview the single frames )
i like much all the 6 pointed stars
PostPosted: Mon Jul 09, 2012 2:14 pm  (#19)
Nice work Erisian - another vote for the stars. Particularly like the Starfleet Medal ;)
PostPosted: Mon Jul 09, 2012 3:19 pm  (#20)
Make that 3 votes for the shurikens Erisian. Nice work. :coolthup
