Hi !
I recreated another cover from an old 2000 Emotif Record.
You can nowadays buy a lot of Drum & Bass records in digital format (when they came out, they were vinyl only), but the original coverart ist most of the time not included.
So you have a few options:
Go to discogs.com and search for the record, if you´re lucky there is a scan or a photo of the cover.
Try the same, but with google.
If both options fail or the discogs pic is of a bad quality: make the coverart yourself with GIMP
And thats what i did.
On top of the pic you can see the photo i googled and worked with.
In the middle you can see two pics of the original coverart, found on discogs, but unfortunately in pretty bad quality and way too small.
Last picture is what i made with GIMP.
So i used the original spacewalk picture, rotated the astronaut after i rendered the pic with a layermask, added the text and after a few hours of hard work i was happy with the result.
I try to add my own touch, because often its impossible to find the right font or in this case, i liked the colours of the original pic and thus decided not to change them into this redish color you have on the original art.
