It is currently Thu Nov 19, 2026 5:43 am
 Post subject: Images I have made with GIMP
PostPosted: Mon Sep 13, 2010 7:17 am  (#1)
I wanted to show you some pictures I made on GIMP.
This is small.the others are in bigger dimensions.if you want and this larger just contact me.
Background 1
Background 2
Background 3
 Post subject: Re: Images I have made with GIMP
PostPosted: Mon Sep 13, 2010 7:25 am  (#2)
that is sweet..so soft
for the others the link lead to a download page without showing the image
PostPosted: Mon Sep 13, 2010 10:08 am  (#3)
That does have a very soft looking effect. =)
Very pleasing to the eye.
PostPosted: Mon Sep 13, 2010 10:23 am  (#4)
It is safe.no problem with this link.you can download the images.
I made the image :brush and I applied a gradient :blend from the basics of the program.It is called Flare Glow Radial 3. :gimp
PostPosted: Mon Sep 13, 2010 10:52 am  (#5)
I really like that. Very nice, Alek. I would rather have links to see your images rather than downloading them.
PostPosted: Mon Sep 13, 2010 11:25 am  (#6)
Thank you O. :) I had them in big dimensions so I said to leave the links and not to fill all the page.they are in 1600 x 1200, :scale and I didn't had the time to scale them.if I found more I may post them,or give to Rod for the new GIMP magazine.
