It is currently Thu Nov 19, 2026 10:14 pm
 Post subject: Black/White Stamp
PostPosted: Sun Aug 05, 2012 9:54 pm  (#1)
Erisian inspired me to do this. Very simple flow. G'MIC Paint followed by G'MIC b/w Stamp. :)
 Post subject: Re: Black/White Stamp
PostPosted: Sun Aug 05, 2012 10:03 pm  (#2)
looks woodcut-like in a modern way
if you swap the white for a shocking pink, it would look a bit warholish
PostPosted: Sun Aug 05, 2012 10:22 pm  (#3)
or
PostPosted: Mon Aug 06, 2012 7:19 am  (#4)
Esper, you gave me an idea when you mentioned "woodcut". Very clean method for woodcarving patterns.
PostPosted: Mon Aug 06, 2012 1:58 pm  (#5)
I had a similar texture as yours in 2.6x Drac; need to find it again and copy it to 2.8. lol
Anyway, thought I would play too. :)
PostPosted: Mon Aug 06, 2012 3:04 pm  (#6)
Glad I'm useful for something. I like your woodcut.
PostPosted: Mon Aug 06, 2012 3:54 pm  (#7)
If you made a shallow carving on wood and used a dark wood filler and sanded it down thats pretty much what it would end up looking like.
That's a good technique.
Alan
PostPosted: Mon Aug 06, 2012 3:57 pm  (#8)
Thanks for the comments. GIMP's bumpmap filter works great for these type renders including sandwriting. Using the mask set to either burn or multiply (and play with opacity sliders) really does help with the filler effect too. :)
PostPosted: Tue Aug 07, 2012 2:34 pm  (#9)
It may just because the colors are brighter but I have to admit I like yours better Lyle. Mine's just too dark overall and hard to see after comparing the two.
