It is currently Thu Nov 19, 2026 9:42 pm
 Post subject: A gift for Maurits Cornelis
PostPosted: Mon Aug 06, 2012 8:22 pm  (#1)
Just a quick commission for the Muse that as you will know live beyond space and time
They wish a gift for a very young dutch child they care for, a certain Maurits Cornelis now almost 10 years old
a simple gift , a chessboard and a transparent globe ....
 Post subject: Re: A gift for Maurits Cornelis
PostPosted: Mon Aug 06, 2012 8:23 pm  (#2)
Now that's a cool Droste with a twist; a new Mathmap preset by chance? :)
PostPosted: Mon Aug 06, 2012 8:42 pm  (#3)
i put in the composer Sphere as first, Droste as second
Only problem i could not save the preset no idea why, but assembled on the fly works well
PostPosted: Mon Aug 06, 2012 11:17 pm  (#4)
Care to share the text code? Would like to play. :)
PostPosted: Mon Aug 06, 2012 11:42 pm  (#5)
MM doesn't allow me to save the text code not sure why.
But i may tell you how to make it on the fly , it is very simple and you may have better luck when saving the filter code
1 open mathmap , open the composer tab
2 now in the filter list search Map> Sphere , click to get it into the composer space
3 do the same for Map> Droste,
in the Composer space connect the "out" of Sphere with the "in " of Droste
setting
The most relevant " external transparency", and "autoset periodicity" ON, from there a lot of possible interesting variable
I was hoping to post a tut on this before going to sleep but is already sunrise and i amgoing to take a good nap
... i hope i may do for tomorrow
PostPosted: Tue Aug 07, 2012 8:44 am  (#6)
Had no issue saving the mmc file PC; not sure why you couldn't.
Below's the code after saving:
(design (node :name "droste" :type "droste" :input-slots ():aux (:x 70.000000 :y 70.000000 ))
(node :name "map_sphere" :type "map_sphere" :input-slots (("in" "droste" "out" )):aux (:x 164.000000 :y 66.000000 ))
:name "droste_sphere" :root "map_sphere" )
PostPosted: Tue Aug 07, 2012 1:34 pm  (#7)
Thank Lylejk i have no idea why i can't save that and the other filters i tried , all i can see is a immediate warning and error messages if i try to use the filter anyway.
I was saving without problem when it just stopped to work
Yesterday i finished the material for the tut but i would like solve this weird problem for saving , before post it
