It is currently Thu Nov 19, 2026 9:30 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
 Post subject: Created from rust
PostPosted: Wed Aug 08, 2012 4:42 am  (#1)
In the beginning was just rust ... just a shot of rust , not even sure if was one of my photo or from some other source (in both cases i believe the real copyright should belong to the Nature :roll: )
If you are impatient scroll to the button to see the final result. ! :mrgreen:
But real natural rust in a photo seldom look sufficiently realistic,is no as the rust that attract more our unconscious attention, not as that in scenery of horror or steampunk movie ...instead i wanted iper-realistic rust
So first i make it seamless, so i used my graphic boost gmic filter to boost luminance and chromatic contrast and to make the detail more popping out
and i consider this the real start , here i post everything very scaled down ,but consider that at 100% zoom the detail look very different from what could be expected
#1
same but seamless
#2
#3
the last 2 are identical except that the last was horizontally stretched to be 4.3
i already show this used as texture ( http://photocomix2.deviantart.com/gallery/#/d58lddb , http://photocomix2.deviantart.com/gallery/#/d58ld3s ) as planned
but i used also to create something else ... let it start with a filter , i had the image open in xnview so i used Fractalius , but if i had opened in gimp i would have used gmic Rodilius with quite similar results
from this i may get how variants i wish using Level...as i said i was on Xnview so i used "automatic level" gimp would habve offered much more options
and the nice thing is that any of those variation remain perfectly seamless as the original
Or i may populate the pattern with weird totemic beings by using mirrors... mirrors are so simple but so magic
and this that i am going to use for the final example
because all this may have a use :
as example i may open the last pattern , that just above in gimp, open mathmap , chose a distort or map filter and
and this last explain very well why i like have very huge pattern (original are about 6x bigger )
and of course same will work for globes, cubes, ellipsoids ...
 Post subject: Re: Created from rust
PostPosted: Wed Aug 08, 2012 10:11 am  (#2)
Those rust images are great PC! :)
The Fractalius image looks like fiberglass up close.
PostPosted: Wed Aug 08, 2012 10:12 am  (#3)
i think this one looks really awesome !
PostPosted: Wed Aug 08, 2012 10:45 am  (#4)
another passage with graphic novel to make a sort of bas relief effect
and in case more seamless rust to start again... :mrgreen:
or , if you prefer more dark ...
PostPosted: Wed Aug 08, 2012 12:31 pm  (#5)
I agree, pretty awesome Photocomix. You could do so many things with the results
PostPosted: Wed Aug 08, 2012 12:35 pm  (#6)
Nice PC, some of these would make cool planets
anyone know why it pauses sometimes, maybe it's my browser
PostPosted: Thu Aug 09, 2012 10:38 am  (#7)
thank for the comments ... nice globe too
i went on playing this time starting from the last image the rusted fence and the results were a lot of very special pattern...
a few examples
A bit less strange
PostPosted: Thu Aug 09, 2012 12:45 pm  (#8)
I love this image and the 3D effect.
Here I have applied what explained in this tutorial: :mrgreen:
http://www.gimpusers.com/tutorials/exploding-planet
PostPosted: Thu Aug 09, 2012 12:56 pm  (#9)
cool...very nice effect Yafu
PostPosted: Thu Aug 09, 2012 3:04 pm  (#10)
I found how to make glass :flirt from rust !! :spring :paint
OOPPSS ,in the 2 above i did forget to switch supersampling on, i did here
PostPosted: Thu Aug 09, 2012 4:15 pm  (#11)
i love this one !
PostPosted: Thu Aug 09, 2012 4:45 pm  (#12)
Wow that is really nice, It looks like a glass frame. How did you get those attractive corners?
PostPosted: Thu Aug 09, 2012 4:58 pm  (#13)
very simple :
first chose a nice symmetrical image..
1 )
pick your pattern i used this (also derived from rust..even if would be hard to guess )
EDIT
the pattern you start from is relevant not only for the color,...what in the corners of the original pattern will remain visible also in the corners of the glass frame (even if more or less modified by the stretching)
2)
now open MathMap/Distort/square
there is only 1 slider, move the slider to the max or almost to to the MAX
..WAIT , before click OK for render contol the "Setting" tab, you want "Supersampling " on
and then just run the filter...
PostPosted: Thu Aug 09, 2012 5:03 pm  (#14)
Thank you PC, that is so beautiful. I should get back to using MathMap again. There are so many goodies there it is hard to remember what they all are.
PostPosted: Thu Aug 09, 2012 5:07 pm  (#15)
i just discovered this trick, i never thought to use that filter in this way before
PostPosted: Thu Aug 09, 2012 5:09 pm  (#16)
I am glad you discovered it PC, now I will enjoy it.
Very nice filter, stole your picture PC :oops: :oops: :oops:
PostPosted: Thu Aug 09, 2012 5:50 pm  (#17)
I like it Molly. Thank you Photocomix for sharing that.
PostPosted: Thu Aug 09, 2012 5:55 pm  (#18)
Thank you Bug
PostPosted: Thu Aug 09, 2012 6:45 pm  (#19)
Beautiful work Molly and PC. I'll have to start experimenting with this filter. :)
PostPosted: Thu Aug 09, 2012 7:07 pm  (#20)
next we need a thread where you people will post all the beautiful picture frames you made :)
