It is currently Thu Nov 19, 2026 9:36 pm
 Post subject: Circles
PostPosted: Mon Aug 13, 2012 11:24 pm  (#1)
some new covers i made tonight for an old classic Dnb track called Circles by Adam F
i didnt want to go for the very obvious soundwave design at first, but after i had the first one ready, it was too easy to just put the waves filter on what i did :mrgreen:
 Post subject: Re: Circles
PostPosted: Tue Aug 14, 2012 1:07 am  (#2)
I like all of them, except something seems different to me with the "Adam" text on the first one. It could be the text offset needs adjustment? Maybe reversed or different colors? I can't quite figure out what it is?
Maybe I'm just seeing things? :oops:
PostPosted: Tue Aug 14, 2012 4:10 am  (#3)
I think I see what you mean Odin. The bottom of the text should be lined up with the cut out line. I think that looks like the center. Very well done though.
PostPosted: Tue Aug 14, 2012 8:34 am  (#4)
Some great work again Esper.
PostPosted: Tue Aug 14, 2012 9:43 am  (#5)
thanks everybody
not sure what you mean, its very minimalistic on purpose and the 3D thing is not really 3D, its just another layer i put behind the dark blue one, because it looks stronger that way
maybe thats what you see: you think its 3D and really its pseudo 3D if that makes any sense :hehe
PostPosted: Tue Aug 14, 2012 9:47 am  (#6)
looks great whatever it is. :teeth
PostPosted: Tue Aug 14, 2012 10:07 am  (#7)
thanks molly, thats very kind
this is really a very positive forum, which is kind of a new experience for me, because im used to extremely trollish and aggressive forums
i really appreciate being here !
PostPosted: Tue Aug 14, 2012 10:30 am  (#8)
We are also glad to have you and your talent.
PostPosted: Tue Aug 14, 2012 9:04 pm  (#9)
I like the minimalist style you have, and your attention to detail.
