It is currently Thu Nov 19, 2026 10:34 pm
 Post subject: a hot paisley
PostPosted: Wed Sep 05, 2012 6:52 pm  (#1)
fire paisleys, anyone? i made this after a tutorial and then i wanted to make a wallpaper with it but i have tried so many layouts and none of them look good :(. in the end i just made a nice picture of it instead, with vague flames in the background.
 Post subject: Re: a hot paisley
PostPosted: Wed Sep 05, 2012 6:54 pm  (#2)
Wooooow!!! That's gorgeous. :hi5 :jumpclap :clap You've got my imagination going again AnMal. :)
PostPosted: Wed Sep 05, 2012 7:07 pm  (#3)
its beautiful ! :luvstruck
and it looks like its really on fire!
i wish the pattern was a bit bigger but apart from that its perfect
what exactly didnt work with the layout of your wallpaper ? what did you try ?
i think a good wallpaper needs space to breathe, so i wouldnt really add much
just more blackness with a hint of fire or any other texture
PostPosted: Thu Sep 06, 2012 12:15 am  (#4)
erisian: thank you!
ah, but you don't seem to need much to get your imagination going, so that's no big achievement on my part:).
esper: thanks!
my thoughts exactly! but i've tried just an empty black background, which was too empty and i like a little framing, so i usually do something to the corners. i tried making a space behind the paisley instead of the plain black but it took too much attention from my paisley even if i turned it down. then i used plain black with the same flame corners i used in this picture and that looks good in the small picture but the flames looked somehow unmotivated in the wallpaper format. then i tried some different types of straight line corners (always just two corners) with more or less toned down fire or glow effects to them and none of them looked good together with the paisley. i tried using the pattern inside the paisley as a corner gradient but that stole attention as well. seems i'e written a whole novel here, but i needed to complain a bit!
PostPosted: Thu Sep 06, 2012 12:28 am  (#5)
how about this (made really quickly):
solid noise with a black layer on 65% and a red layer on Overlay mode
PostPosted: Thu Sep 06, 2012 10:28 am  (#6)
Here's my effort.
PostPosted: Thu Sep 06, 2012 11:30 am  (#7)
esper: thanks for taking the time :) ! hmm, i think i could do something with that. the red isn't perfect with the paisley, but i could play with it and see what happens.
erisian: :wow that's one delicious paisley! :hi5 looks like a paisley made out of a sliver of the moon, how lovely is that? would you tell how you made it, please?
PostPosted: Thu Sep 06, 2012 11:55 am  (#8)
here's my final decision for the wallpaper (at reduced size):
PostPosted: Thu Sep 06, 2012 12:04 pm  (#9)
Very nice! :)
PostPosted: Thu Sep 06, 2012 12:09 pm  (#10)
thank you, rod :)
PostPosted: Thu Sep 06, 2012 12:20 pm  (#11)
That's nice AnMal.
As for mine, I will try to remember.
The background was made using both solid noise clouds and plasma desaturated and colorized and a red-transparent gradient on top. I played with layer modes but can't remember which I used.
The paisley was made with paths converted to selections on different layers and flood filled. The top two layers were blurred. The bottom paisley was duplicated, desaturated and bevelled and put in either overlay or grain merge mode. The bottom paisley was also used to make the glow layer.
Hope this helps.
PostPosted: Thu Sep 06, 2012 12:23 pm  (#12)
that came out nicely !
PostPosted: Thu Sep 06, 2012 2:54 pm  (#13)
none of my attempts to make moon paisleys was very successful, but i thought these three were nice anyway.
PostPosted: Thu Sep 06, 2012 3:16 pm  (#14)
They are really nice. I like the first one best.
PostPosted: Thu Sep 06, 2012 4:49 pm  (#15)
thanks, brother. but you're a strange sort - the middle one is of course the best :)
PostPosted: Thu Sep 06, 2012 5:37 pm  (#16)
You need to drink some coffee. :hehe
PostPosted: Thu Sep 06, 2012 5:42 pm  (#17)
:gaah you used a dirty word!!
PostPosted: Thu Sep 06, 2012 5:43 pm  (#18)
:rofl
PostPosted: Thu Sep 06, 2012 9:58 pm  (#19)
Nice, I like your last version and wallpaper! :mrgreen:
PostPosted: Thu Sep 06, 2012 11:28 pm  (#20)
mokonafan: thank you! i am almost too pleased with myself when i look at my new wallpaper :)
