It is currently Thu Nov 19, 2026 10:35 pm
 Post subject: Fake painting
PostPosted: Sun Sep 09, 2012 5:48 pm  (#1)
Makes me look very old (No comments Lyle :hoh ) but I used selections-paths-selections to create this. The canvas texture was created using the script from here. http://www.gimpchat.com/viewtopic.php?f=9&t=5199 converted to a gradient, desaturated duplicated and rotated 90 degrees and put in multiply mode.
 Post subject: Re: Fake painting
PostPosted: Sun Sep 09, 2012 6:22 pm  (#2)
i'm full of questions. is this a painting or a fake painting (meaning using a photo?) how do you use selections-paths-selections to fake a painting? and of course, are we all invited for your hundredth birthday bash next week? :scram
(btw, cretive use of that script, i think)
PostPosted: Sun Sep 09, 2012 6:23 pm  (#3)
That's an interesting effect. It could be used with the dark brown right side replaced with another version of your picture or something completely different like flowing thoughts (music, flowers, numbers, beach, sky, trains, planes, automobiles etc.)
PostPosted: Sun Sep 09, 2012 6:27 pm  (#4)
Er - 99th AnMal! :hoh It helps to use threshold but I didn't. Create selections of various value ranges using select by colour on your photo and convert them to paths. On separate layers convert each path to a selection and flood fill with varying greys. Make your photo and background layer invisible and merge visible layers. Make all layers visible then experiment with layer modes, saturation etc.
Excellent thinking Odin. :)
PostPosted: Sun Sep 09, 2012 6:36 pm  (#5)
whew, that sounds like a lot of work!
PostPosted: Sun Sep 09, 2012 6:38 pm  (#6)
Not as much work as creating Celtic Knots!
PostPosted: Sun Sep 09, 2012 6:41 pm  (#7)
hmm... you have a point there. especially if you can't help tweaking it all the time :).
PostPosted: Sun Sep 09, 2012 6:42 pm  (#8)
Don't encourage me. I've still got my knot paths saved and I will tweak. :hehe
PostPosted: Sun Sep 09, 2012 6:45 pm  (#9)
:hehe you're not the only one. those paths made from selections that tutorialgirl uses make it very elegant and very exact and if you're a very messy person by nature you just need a bit more mess in your knotwork.
PostPosted: Sun Sep 09, 2012 6:47 pm  (#10)
he he he.
I will say that I like the almost vexel result. The canvas texture needs to go though (or is it a way to hide the wrinkles. ;) ). :)
PostPosted: Sun Sep 09, 2012 6:52 pm  (#11)
AnMal - I make a mess when I'm trying to be precise. I tried to make a selection from one of my knot paths and it was all over the place. I ended up having to stroke the path then fuzzy select the outside of it to get a reasonable selection.
Lyle - :hoh :hoh :hoh - I'm English and I've never in my life heard the word vexel. Please explain or I'll take it as an insult. :hoh
PostPosted: Sun Sep 09, 2012 6:57 pm  (#12)
hmmm, gimp already has a way to apply a picture to make it look like it is on canvas....just go to Filters>Artistic>Apply Canvas...and it will bring up this pop up screen...
and then you can change your settings. here is a example of how it can look ....
so i guess i was wondering why you would need to download the script you used?...just asking..
PostPosted: Sun Sep 09, 2012 6:59 pm  (#13)
that does sound messy :). i was ready to start crying when i was nearly finished with the paths of my second knot and zoomed out and saw that two of the outer paths had broken loose somehow and i had no idea how to put them back.
PostPosted: Sun Sep 09, 2012 7:02 pm  (#14)
Partly it was an accident. I never intended to use the script that way. Also I like to find other ways of doing things. Also, oils and acrylics are thick enough to cover canvas texture so in a real painting you won't see it anyway - it's just a digital gimmick.
AnMal - an artist who doesn't cry occasionally isn't an artist. :)
PostPosted: Sun Sep 09, 2012 7:06 pm  (#15)
ok..dang :hoh i was hoping i knew something that someone on here didn't already know... :)
PostPosted: Sun Sep 09, 2012 7:08 pm  (#16)
You'll be lucky! :hehe
PostPosted: Sun Sep 09, 2012 7:56 pm  (#17)
A vexel is the bitmap editor's way of faking a vector. http://en.wikipedia.org/wiki/Vexel
PostPosted: Sun Sep 09, 2012 8:14 pm  (#18)
great work, i love it ! :P
its true, it makes you look old because the colors make the corners of your mouth and eyebrows appear to hang down, but this is because parts of the colored selections look and act like shadows
i was wondering if you could achieve the same effect with posterize
also you could make a (multilayer) stencil from your work (if you simplified it some more), and then cut and spray it
im a big fan of stencil graffiti !
PostPosted: Sun Sep 09, 2012 8:51 pm  (#19)
Ok, cough up the tut on how it's done. I like the results.
PostPosted: Mon Sep 10, 2012 5:31 am  (#20)
I don't think you would have as much control with posterize. Graffitti...
GMS - sorry, I haven't been able to replicate the effect very effectively.
