It is currently Thu Nov 19, 2026 11:18 pm
 Post subject: Cran-Tau
PostPosted: Sat Sep 25, 2010 8:10 am  (#1)
Forgot that I even had RobA's Random Density map. He copied a link at the registry (http://registry.gimp.org/node/10774#comment-2131) to where he linked it at GIMPTalk, but of course, GIMPTalk is not working again (not really an inside joke to you guys here). lol
I checked Rob's website, but didn't see that he copied it there. It is sort of slow, but really cool results (if you have a good brush to use that is) can be done. Closest thing that I know to a Jigsaw Image Mosaic which I've yet to run across a program for. Have one for Puzzle Imag Mosaic's, but do like the dimensionality of JIM's better. :)
I call this one Cran-Tau (a Cranberry rendition in the form of the Yin/Yang symbol). :)
File comment: Threw a bunch of cranberries into the air and look what they formed. :)
 Post subject: Re: Cran-Tau
PostPosted: Sat Sep 25, 2010 8:27 am  (#2)
OK; looks like GIMPTalk's back up for a few seconds. Rob's thread is below. :)
http://www.gimptalk.com/forum/viewtopic.php?f=9&t=30359
PostPosted: Sat Sep 25, 2010 8:58 am  (#3)
I had to send a link to your cranberry Yin-Yang post to my brother. He's a retired cranberry grower in Bandon, Oregon.
That is very cool. :hehe
Unfortunately, your link to GT wasn't quick enough for me. GT was down when I tried it. :hoh
PostPosted: Sat Sep 25, 2010 12:13 pm  (#4)
Just tried it again O; works. Get it while you can. lol
Also have to add an arg. since it should have been Cran-Tao, not Cran-Tau. lol
PostPosted: Sat Sep 25, 2010 1:15 pm  (#5)
Thanks Lyle. Got it and did a VERY belated reply to the thread. I guess I missed RobA's last post. Now off to play. :tehe
Played with my star brush. First I did lines with the path tool and stroked the lines on the black bg with a white brush and blurred. Ran the filter
Then I did a circle on another black background filled it with white and blurred. Then ran the filter so I'd have a cluster of stars in the center.
The bubble background is not one I made but those bubbles give me ideas for the filter. :hehe
This is a filter that is extra nice for those times when you want something scattered randomly.
PostPosted: Sat Sep 25, 2010 1:28 pm  (#6)
interesting, tried a simple circle of rings just to see how it worked. Not sure what the third parameter does.
PostPosted: Sat Sep 25, 2010 3:37 pm  (#7)
Is this the start of another binge for me? Maybe. lol
PostPosted: Sat Sep 25, 2010 5:09 pm  (#8)
Those look like M&M's Lyle. Yum.
I used a white layer to use as a map for the background. Seems to have worked well.
PostPosted: Sat Sep 25, 2010 5:53 pm  (#9)
:jumpclap :jumpclap :jumpclap
PostPosted: Sat Sep 25, 2010 6:26 pm  (#10)
Excellent O; I can see that I (and hopefully many more) will get some cool results using Rob's fantastic Script-fu. Saw later that he is hosting his align to grid version at his site by the way, but I like the all random one better (but I do see other possibilities for more orderly fills). I actually edited the grid one so that it and Rob's original can co-exist on my PC (hope you don't mind Rob). I can't Script-fu, but it really wasn't that hard to change. :)
PostPosted: Sat Sep 25, 2010 7:18 pm  (#11)
I call this one Arcimboldo's Planet. Used Rob's Script-fu and then applied lens distortion to curve it some. :)
PostPosted: Sat Sep 25, 2010 7:44 pm  (#12)
I wanted to see what those other settings did. On a transparent layer I made a 6-sided polygon and filled it with a pattern. Then made a new transparent layer for brushing.
I used the pattern-filled shape as the density map and checked the box where it says Use map alpha channel for Density and draw with map colour.
I have a grayscale spiky brush I used for painting. If you check Invert Map, the brush fills in the area around the shape - that's just a side note to explain what happens.
Anyway, the brush gets colored from the colors in the pattern on the map. It's a delightful, versatile script.
These are my results.
PostPosted: Sat Sep 25, 2010 7:48 pm  (#13)
I love it!!!! :clap :gimp
PostPosted: Sat Sep 25, 2010 7:51 pm  (#14)
In case it go's down again here is the script code
Just save it as a SCM extension in your scripts folder, find it in /Filters/Map/Random Density Map
in the program menu.
Nice script ill have to try this out later. thanks btw. =)
; random_density_map.scm
; by Rob Antonishen
; http://silent9.com
; Version 1.0 (20080408)
; Description
; Script to draw a specified number of random points with the currently
; selected brush, using a density mask.
; Will appear in Filters->Map Menu
; based on random.scm
; by Charles Cave <[email protected]>
; http://members.optusnet.com.au/~charles57/GIMP
; License:
; This program is free software; you can redistribute it and/or modify
; it under the terms of the GNU General Public License as published by
; the Free Software Foundation; either version 2 of the License, or
; (at your option) any later version.
; This program is distributed in the hope that it will be useful,
; but WITHOUT ANY WARRANTY; without even the implied warranty of
; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
; GNU General Public License for more details.
; The GNU Public License is available at
; http://www.gnu.org/copyleft/gpl.html
(define (script-fu-random-density-map img inLayer inDensityMap inInvertMap inUseAlpha inIterations inMargin inBailout)
  (let* (
        (x1 0)
        (y1 0)
        (ctr 0)
        (x2 (car (gimp-drawable-width inLayer)))
        (y2 (car (gimp-drawable-height inLayer)))
        (xMap (car (gimp-drawable-width inDensityMap)))
        (yMap (car (gimp-drawable-height inDensityMap)))
        (x 0)
        (y 0)
        (map-type 0)
        (get-val 0)
        (test 0)
        (thresh 0)
        (*randompoint* (cons-array 2 'double))
        (drw-width 0)
        (drw-height 0)
      (lc 0)
  ; define drawable area for the algorithm
  (set! x1 (+ x1 inMargin))
  (set! x2 (- x2 inMargin))
  (set! y1 (+ y1 inMargin))
  (set! y2 (- y2 inMargin))  (set! drw-width  (- x2 x1))
  (set! drw-height (- y2 y1))
  ;get map type:  RGB-IMAGE (0), RGBA-IMAGE (1), GRAY-IMAGE (2), GRAYA-IMAGE (3), INDEXED-IMAGE (4), INDEXEDA-IMAGE (5)
  (set! map-type (car (gimp-drawable-type inDensityMap)))
  ; make sure maps isn't indexed
  (if (or (= map-type INDEXED-IMAGE) (= map-type INDEXEDA-IMAGE))
    (gimp-message "Density Map can not be indexed!") ; error
   (if (or (not (= x2 xMap)) (not (= y2 yMap)))
      (gimp-message "Density Map must be the same size as the active layer!") ; error
       ;it begins here
      (begin
       (gimp-context-push)
       (gimp-image-undo-group-start img)
       ; set up progress bar
       (gimp-progress-set-text _"Rendering Random masked Image")
       (while (and (< ctr inIterations) (< lc inBailout))
         ; get a random location
         (set! x (+ x1 (random drw-width )))
         (set! y (+ y1 (random drw-height)))
         ; get the pixel value at that spot
         (set! get-val (cadr (gimp-drawable-get-pixel inDensityMap x y)))
         ; pick a number, any number
         (set! thresh (random 255))
         (if (and (= inUseAlpha TRUE) (= (car (gimp-drawable-has-alpha inDensityMap)) TRUE))   ; if using alpha
          (begin
            (set! test (aref get-val 3))   ; test threshold against alpha ( index 3)
            (gimp-context-set-foreground (list (aref get-val 0) (aref get-val 1) (aref get-val 2)))  ;set brush colour
          (if (or (= map-type GRAY-IMAGE) (= map-type GRAYA-IMAGE))  ;  else if greyscale
            (set! test (aref get-val 0))  ; test threshold against colour ( index 0)
            (if (or (= map-type RGB-IMAGE) (= map-type RGBA-IMAGE))  ; else if colour
             (set! test (/ (+ (aref get-val 0) (aref get-val 1) (aref get-val 2)) 3)) ; test threshold against average of r g and b
             (set! test 255) ;  else threshold to full value (always draw)
         (if (= inInvertMap TRUE)  ; reverse the map if invert option
          (set! test (- 255 test))
         (if (< thresh test)    ; compare threshold against random value
          (begin
            (set! ctr (+ ctr 1))       ; increment counter
            (set! lc 0)
            (aset *randompoint* 0 x)   ; set the paint array
            (aset *randompoint* 1 y)
            (gimp-paintbrush-default inLayer 2 *randompoint*) ; paint point
            (gimp-progress-update (/ ctr inIterations))  ;update progress bar
         (set! lc (+ lc 1))
       (if (>= lc inBailout)
         (gimp-message "Bailout Parameter Exceeded - Aborted!") ; error
       (gimp-progress-end)
       (gimp-image-undo-group-end img)
       (gimp-displays-flush)
       (gimp-context-pop)
(script-fu-register "script-fu-random-density-map"
                    "<Image>/Filters/Map/Random Density Map..."
                    "Draw a specified number of random points with the currently selected brush, using a density mask."
                    "Rob Antonishen"
                    "Rob Antonishen"
                    "April 2008"
                    "RGB*, GRAY*"
                    SF-IMAGE       "Image"         0
                    SF-DRAWABLE    "Drawable"      0
                    SF-DRAWABLE    "Density Map"   -1
                SF-TOGGLE      "Invert Map"    FALSE
               SF-TOGGLE      "Use map alpha channel for Density and draw with map colour"  FALSE
                    SF-ADJUSTMENT  "Number of points to draw"     '(10 1 10000 10 100 0 0)
                    SF-ADJUSTMENT  "Border Margin (pixels)"       '(0 0 100 1 6 0 0)
                    SF-ADJUSTMENT  "Bailout Threshold"            '(200 100 2000 10 100 0 0)
PostPosted: Sat Sep 25, 2010 8:09 pm  (#15)
Haven't played with that feature yet O, but your result does look cool. Good idea Rod; didn't want to step on Rob's shoe so just linked it earlier. It definitely needs a better host. Maybe Rob will officially release it to the registry. I'll ask him at GIMPTalk. :)
PostPosted: Sat Sep 25, 2010 8:35 pm  (#16)
If Rob see's it here and asks me to remove it i will.I do not think he will mind as long as it's not being sold or copyright abuse isn't going on.
Thanks Rob in advance for the script. =)
Question though:
Can someone explain exactly how to use this script?
Every time i run it no matter what setting i use i get an integer error.
I created a black canvas, created another layer with a white blurred circle,created another white layer to run the filter on, painted (on the white layer) with a red brush (size 10), tried the filter with default settings and got the error still.
Any help?
PostPosted: Sat Sep 25, 2010 8:47 pm  (#17)
Any help?
The white blurred circle should be merged down to the black canvas. Then be sure that black and white layer is selected in the Density Map dropdown.
You can also make the additional white layer a transparent layer if you want. Select the white or transparent layer before starting the script.
PostPosted: Sat Sep 25, 2010 10:57 pm  (#18)
Hi-
Glad you found a good use! As pointed out I rewrote the script to "fill" from the top down in a (optionally jittered) grid. This is because the main use I have for the script is in my map making.
For example this: http://fc01.deviantart.net/fs70/i/2010/ ... _ffaat.jpg
Where I don't want completely random trees, but want the ones "in front" to over-paint the ones "behind" when running the script.
The random one you posted here could use some speedup (I should try it in python which would be much faster to sample the canvas).
-Rob A>
PostPosted: Sat Sep 25, 2010 11:08 pm  (#19)
I know your are a map guy Rob; cool use of your Grid version for laying out the trees. Not sure if you ever heard of Jigsaw Image Mosaics, but I think I can coax your grid version to get a better result to approximate these (haven't tried yet; need to create a gih set with the object that will fill an arbitrary container (selection island) and see. :)
PostPosted: Sat Sep 25, 2010 11:13 pm  (#20)
lol ... now it keeps telling me the density map has to be the same size as the layer?
