It is currently Thu Nov 19, 2026 10:35 pm
 Post subject: ESPrd experiments Pt. 2
PostPosted: Mon Sep 17, 2012 11:16 pm  (#1)
these stars drive me crazy :hehe
totally improvised - 5 hours :shock:
 Post subject: Re: ESPrd experiments Pt. 2
PostPosted: Mon Sep 17, 2012 11:53 pm  (#2)
There quite a bit going on, how many layers?
PostPosted: Mon Sep 17, 2012 11:57 pm  (#3)
about 20+ ;)
but the flowerstar has another 17
PostPosted: Tue Sep 18, 2012 1:53 am  (#4)
Beautiful work Esper. Keep em coming! :)
PostPosted: Tue Sep 18, 2012 6:42 am  (#5)
Esper - There is a lot going on there and I like it. I do have a question tho. In your original explanation/tutorial on how to make the star/flower thingy, you mentioned rotating the path. I never did figure out how to do that. I ended up just making my colored layer and rotating that. How did you rotate the path?
PostPosted: Tue Sep 18, 2012 6:51 am  (#6)
Use the rotation tool and change it to path mode (right icon at top of tool options)
PostPosted: Tue Sep 18, 2012 6:55 am  (#7)
Crap! That was too easy. I was looking and right clicking all over the paths dialog trying to find a way to do it. Ha Ha. This is embarrassing.....
PostPosted: Tue Sep 18, 2012 10:12 am  (#8)
Drac, remember, i was going to try to make a gear, so i rotated rectangles with a circle in the middle
the plan was to rotate another, a bit wider rectangular selection, and then somehow subtract portions of the smaller from the bigger one, thats i why i started to make rectangular paths
then i had four of those paths and merged - when i filled them with black i discovered that some of the intersections were not filled and it looked like a flower
then madness came :hehe
PostPosted: Tue Sep 18, 2012 1:03 pm  (#9)
esper: :yr - everything you do with those rotating paths-flowery-stars is just awesome! i love the diamonds too, i can well imagine that piece took you five hours. stay mad for some more time, please :)!
