i made another cover (this time not a replica of an actual cover), not sure if its worth posting - its simple
so this label is called DSCI4 (the leet way of writing Decipher) and it has this barcode background
so i googled 'barcode generator' and made my barcode here:
http://barcode.tec-it.com/barcode-gener ... px?LANG=de(it actually reads DSCI4)
made my text, and as usual i customized it a bit (turned the text into a path, and then scaled the height by 50%), then made a rectangular selection around it and filled the copied barcode png with the fill tool
the rest should be obvious
