It is currently Thu Nov 19, 2026 6:19 am
 Post subject: Soft Celtic Pop Render+ Celtic Pop Xtrem
PostPosted: Sun Sep 26, 2010 7:35 am  (#1)
I did a so nice celtic triple spyral...soft and neat
but then went twisted...
in that confusion hide also a colony of floating N-dimensional Globins (that you may spot for the yellow eyes and white teeth )
last
 Post subject: Re: Soft Celtic Pop Render+ Celtic Pop Xtrem
PostPosted: Sun Sep 26, 2010 11:45 am  (#2)
I love the stories you tell with your art PC.
Very imaginative. =)
PostPosted: Sun Sep 26, 2010 12:49 pm  (#3)
but did you spot the chain of Ndimensional Goblins ? :spring
PostPosted: Sun Sep 26, 2010 1:25 pm  (#4)
How do you do that twisting? I was sure I'd seen something in G'MIC or MathMap that did that, but can't find it.
PostPosted: Sun Sep 26, 2010 1:46 pm  (#5)
Love it when you go wack PC. :)
PostPosted: Sun Sep 26, 2010 2:42 pm  (#6)
the "goblin " chain ? that was MM droste used on the render with "hyperdroste" option
The BG of the second was also with droste but i did 2 different (with "show both poles" ) and i merged down in difference mode
thank :seeya
PostPosted: Sun Sep 26, 2010 3:24 pm  (#7)
I have a lot of learning to do about that, PhotoComix. At least I have something to go on so I can experiment.
PostPosted: Sun Sep 26, 2010 3:43 pm  (#8)
so you may like a follow up...
Twisting ? Me ?
@ Oregonian
for i think for this kind of effects you should find more colorful original
PostPosted: Sun Sep 26, 2010 5:11 pm  (#9)
Reminds me of things we did in the 70s, most of which was frowned down upon.
PostPosted: Sun Sep 26, 2010 7:03 pm  (#10)
yup...many just ended in some waste bin, and anyway it was as always a lot of garbage, as always find good art end to end in sorting out few gems from a lot of manure. :gaah
I was a Triple Spiral. by PhotoComix_Mandala, on Flickr
PostPosted: Sun Sep 26, 2010 7:28 pm  (#11)
Let me try this again: (My post disappeared... again)
I would love to know more about how you created the first image, with the swirls!
My Sigs = My Photos
PostPosted: Mon Sep 27, 2010 4:40 am  (#12)
@greg
That is very easy because i was so lucky to have this SVG
http://upload.wikimedia.org/wikipedia/c ... filled.svg
Only the shape filled in black ,but a very good start
then
1
open the SVG chosing the best size
2
get rid out of the BG:
select /clear
3
i want really smooth edges so i grow the selection of 2 pixel then .. of Gaussian blur (about 20px )..again grow the selection and more of gaussian blur (was about 15px)
4
then select again the triple spyral and feather the selection
5
Gradient tool with radial option and full hue gradient (i think is already in gimp )
i stroked from the very center
see more here http://www.flickriver.com/photos/photoc ... 916118133/ :paint
oh well the last a sphere and a cube
pattern with sphere by PhotoComix_Mandala, on Flickr
and a cube
cube by PhotoComix_Mandala, on Flickr
