It is currently Thu Nov 19, 2026 11:13 pm
 Post subject: As a flower
PostPosted: Tue Oct 09, 2012 8:37 pm  (#1)
not exactly the macro of a flower
 Post subject: Re: As a flower
PostPosted: Tue Oct 09, 2012 8:56 pm  (#2)
How do you create these things? Is there a tutorial or something? I would like to try something like this!
PostPosted: Tue Oct 09, 2012 9:18 pm  (#3)
that is again mandelbulb3d ... on fractalforums and DA there are several tut but the best i believe is just search a image you like with parameters, copy and paste the parameters and try to change something little by little
(usually i first change position , put more lights then i start to modify here and there...
I start 2 times to make a unproductive tut but i never finished
