It is currently Fri Nov 20, 2026 1:00 pm
 Post subject: POVRay Tithonia
PostPosted: Tue Oct 16, 2012 12:48 am  (#1)
Haven't played with Kevin's POVRay output script-fu in a few months so why not. :)
 Post subject: Re: POVRay Tithonia
PostPosted: Tue Oct 16, 2012 1:35 am  (#2)
Where is The POV output script?
PostPosted: Tue Oct 16, 2012 2:56 am  (#3)
Lylejk started the thread about POVSphere http://www.gimpchat.com/viewtopic.php?f=22&t=4480 but I got carried away with writing a script-fu version, the last version of which is at this post: http://www.gimpchat.com/viewtopic.php?f ... =80#p56902
And lylejk, nice one... hexagons looking good.
Kevin
PostPosted: Tue Oct 16, 2012 8:41 am  (#4)
Thanks, Kevin.
I'm new to POV, I've only used it with defaults. The presets are good but to master it would take some time.
File comment: Before and After
PostPosted: Tue Oct 16, 2012 1:14 pm  (#5)
I have to say again how much I appreciate Kevin's cool Script-fu. Much better then the original plugin that I found back then (by a long mile). Wish I was more into the 3D apps out there, but I prefer photo manipulation. Just easier for me to do then create stuff from scratch. :)
PostPosted: Tue Oct 16, 2012 1:38 pm  (#6)
lylejk: your tithonia seems to agree with any treatment you put it through :). i have to try that script-fu, this looks really fun!
PostPosted: Tue Oct 16, 2012 2:34 pm  (#7)
Note that I processed the result in POVRay AnMal, but you can get some good result with the GIMP only part too of the script-fu too, but I usually port the resulting pov file into POVRay then do some additional tweaks with the output in GIMP of course. POVRay is free (can't remember if it is Open Source and too lazy to look that up right now; lol) by the way. :)
PostPosted: Fri Oct 19, 2012 2:19 pm  (#8)
Lyle, you've got me at it again ;)
I've decided to re-do the script in Python to make it more robust, and along the way I've added a new shape. The script isn't ready yet, but just as a teaser:
This is the GIMP sample picture (not POV-Ray), 6-point stars, sample layer duplicated and edge-detected with the original picture on the bottom layer.
Original picture is here:
Kevin
PostPosted: Fri Oct 19, 2012 5:13 pm  (#9)
OK Kevin; where's the link? lol
Look forward to seeing the update when you put the final touches. Thanks a heap for your effort again by the way. :)
PostPosted: Fri Oct 19, 2012 8:41 pm  (#10)
Cool :clap :clap :clap
Kevin
PostPosted: Sat Oct 20, 2012 2:35 pm  (#11)
Bit more teasing:
Results in POV-Ray this time
I've just got to tidy up the code and put lots more comments in so that next time I come to look at it I can understand what I've done :shock:
Kevin
PostPosted: Sat Oct 20, 2012 2:41 pm  (#12)
I'm looking forward to trying out your script.
PostPosted: Sat Oct 20, 2012 3:47 pm  (#13)
Ready for trying now: viewtopic.php?f=22&t=4480&p=69885#p69885
Kevin
PostPosted: Sat Oct 20, 2012 3:51 pm  (#14)
Very cool Kevin, keep going :teeth
PostPosted: Thu Mar 27, 2014 9:40 pm  (#15)
OK Kevin; how do you get the angled mapping again with Povray file? Still like this now Python plugin version. Kudos again for your effort with this. :)
PostPosted: Fri Mar 28, 2014 2:01 am  (#16)
You change the position of the camera:
camera
  location  <2, 0.25, -3.5>    // x, y, z position of the camera
  right     4/3*x
  look_at   <2, 0.25,  0.0>    // x, y, z position the camera is pointing at
camera
  location  <-0.4, -0.7, -2.0>    // x, y, z position of the camera
  right     4/3*x
  look_at   <1.2, 0.25,  0.0>    // x, y, z position the camera is pointing at
By default the script puts the camera to be looking square onto the objects.
Kevin
PostPosted: Fri Mar 28, 2014 4:31 am  (#17)
Thanks Kevin; not a Povray guy and I only toyed with it a few times but never understood how to map at different positions. Never thought to try some math and the camera location. :)
