It is currently Thu Nov 19, 2026 11:14 pm
 Post subject: Usurper saga - The Empress
PostPosted: Sun Oct 21, 2012 4:21 pm  (#1)
(click for DA version)
Concept art from game project with work title "The Usurper".
All from scratch and my imagination. This is partially Asian-inspired but some ideas were also taken from European royal gowns - and the world concept is really a mixture of all sorts of cultures. I didn't want the Empress to have a crown; the form of the "halo"-thingie also has some significance, as does (of course) the scar across her face.
Done in MyPaint + GIMP, over a bunch of hours. Comments and feedback welcome as usual!
Griatch
 Post subject: Re: Usurper saga - The Empress
PostPosted: Sun Oct 21, 2012 4:26 pm  (#2)
Really nice and the detail is amazing.
PostPosted: Sun Oct 21, 2012 4:39 pm  (#3)
Outstanding, except I don't know if it is just my eyes but her left arm, the one holding the fan seems very thin between the wrist and the forearm.
PostPosted: Sun Oct 21, 2012 4:43 pm  (#4)
griatch: busvackert!!! i love the mix of cultural references and you've used the colours so well here.
PostPosted: Sun Oct 21, 2012 5:05 pm  (#5)
great great picture !!
the colors, the detail, the landscape
as somebody who was trained to make clothes as a profession, there is a lot i could criticize about her dress....
some of the detail you painted wouldnt work in real life or look differently
the train (or whatever you wanna call it) and the sleeves mostly
but i know that painting clothes is very hard and you did a great job !
on the other hand i do love all the patterns and the transparency is very well painted, imo
PostPosted: Sun Oct 21, 2012 5:13 pm  (#6)
Thanks for the comments and feedback!
@molly:
You were absolutely right - the hand wrist was too thin. Fixed it now. Thanks!
@Esper:
The only thing I know is missing is a latch to hold her cape together in the front - without it the whole thing will be hard to move forward with. I didn't add it since I figure this is a sort of "pose" painting - she stands model for the painter and thus is not walking about.
I'm most willing to hear more details about what you think wouldn't work "realistically" with the dress. :)
Griatch
PostPosted: Sun Oct 21, 2012 5:33 pm  (#7)
Update: Added some fixes to the gown that might make its functionality a bit clearer. :)
Griatch
PostPosted: Sun Oct 21, 2012 5:34 pm  (#8)
i dont think i can explain all that with text alone and in english
it has something to do with how seams change the flow of fabric and the grain in which the fabric is cut and how you would construct such a dress in real life
tbh, i see this kind of "oddity" all the time in fantasy designs and probably most people wont realize or care
it just has to look fantastic and thats fair enough
im probably biased and over critical
PostPosted: Sun Oct 21, 2012 5:44 pm  (#9)
Oh, that's too bad, it sounds like you have some very interesting expertise. It's true that the fall of fabric is a tricky thing and once going beyond simple garments it quickly becomes hard to determine just how things fall without a reference. I did use the gown of the Empress of Austria as a sort of base inspiration for this gown, although the end result is hardly similar.
Griatch
PostPosted: Mon Oct 22, 2012 5:02 am  (#10)
This is your most gorgeous work yet and I really can't find anything that needs improvement.
PostPosted: Tue Oct 23, 2012 7:45 am  (#11)
Thanks Erisian. :-)
I have updated this image with feedback from around the web, such as small changes to clothes, face, hands and sleeves.
Griatch
PostPosted: Wed Oct 24, 2012 11:50 am  (#12)
Very lovely!
My main thing I'm confused on is why her side seems to stick out a lil bit...?
Is that because she's turned or something? :X
PostPosted: Wed Oct 24, 2012 12:28 pm  (#13)
It's called a rib cage, Moko. :)
It's hard to tell under all those clothes, but she's on her toes (probably high heels) and is holding quite a pose here, jutting her chest out. The cut of her dress happen to coincide with the angle of the rib cage which is what you see.
Griatch
PostPosted: Wed Oct 24, 2012 12:42 pm  (#14)
Ah! Okay! Now I get it. xD
Thank you. XD
PostPosted: Thu Oct 25, 2012 12:23 pm  (#15)
Griatch
PostPosted: Thu Oct 25, 2012 8:03 pm  (#16)
Griatch, I love your work! I just went and looked at all your stuff on DA; it's really breathtaking. I like how you decided not to use a crown; it has such an element of unexpectedness!
“For man, as for flower and beast and bird, the supreme triumph is to be most vividly, most perfectly alive.” David Herbert Lawrence
PostPosted: Mon Oct 29, 2012 2:28 am  (#17)
Thanks mariawendt, glad you like it!
Griatch
