It is currently Thu Nov 19, 2026 11:13 pm
 Post subject: Dinnerware Text Effect
PostPosted: Sat Oct 27, 2012 4:15 pm  (#1)
I grabbed this font from Dafont.com called "DinnerTime" and proceeded to bump map, make some selections, and apply a few gradients to make the relief areas on the spoons and knifes then just applied some curves and a metallic color.
I also attached my new Chrome Rivets pattern I made to use with this image. The pattern is just the rivets and does not have the background shown in the sample pic below.
Of course I had to make one in sterling silver and another in gold plate for special occasions.
Chrome Rivets.pat [244.18 KiB]
Downloaded 122 times
 Post subject: Re: Dinnerware Text Effect
PostPosted: Sat Oct 27, 2012 4:42 pm  (#2)
They look really good, what's for dinner? :pizza
PS, and thanks for the .pat.
PostPosted: Mon Oct 29, 2012 4:49 pm  (#3)
It looks really sweet. I love how you took a flat font and turned it into a sweet-looking 3-D font. :kpix
“For man, as for flower and beast and bird, the supreme triumph is to be most vividly, most perfectly alive.” David Herbert Lawrence
PostPosted: Mon Oct 29, 2012 5:03 pm  (#4)
Thanks sweetie. It was just a fun thing that's been sitting in a to do pile for a long time.
AnMal - You getting this? I'm getting caught up :mrgreen:
Odin - I don't know what happened, but I just noticed my reply to you is not here. I guess I must have hit the wrong button by mistake. Anyway it was basically thanking you for your comment and judging from your choice of smileys that it looks like we're having pizza so no knives, forks, spoons or chopsticks are required. LOL
