It is currently Thu Nov 19, 2026 11:14 pm
 Post subject: Painting: Mount Everest
PostPosted: Mon Oct 29, 2012 9:50 am  (#1)
 Post subject: Re: Painting: Mount Everest
PostPosted: Mon Oct 29, 2012 9:56 am  (#2)
Wow, did you paint that from scratch Mike? It is very good.
PostPosted: Mon Oct 29, 2012 2:12 pm  (#3)
Really nice
PostPosted: Mon Oct 29, 2012 4:39 pm  (#4)
It looks really good! I don't think the frame does the painting justice, though. It looks like a marble texture just placed into a rectangle selection and doesn't look very good. Hope you don't mind my saying so, by the way. ;) But the painting itself is stupendous!!
“For man, as for flower and beast and bird, the supreme triumph is to be most vividly, most perfectly alive.” David Herbert Lawrence
PostPosted: Mon Oct 29, 2012 9:21 pm  (#5)
Is that a painting or a picture with filters?
Either way, nice! I don't like the frame though.
PostPosted: Wed Oct 31, 2012 9:26 am  (#6)
Nice work Mike. Am I correct in guessing this was a photo with filters added? I like the frame but it clashes with the painting.
PostPosted: Sun Nov 04, 2012 8:59 am  (#7)
OK. Here's the answer to the questions:
My wife painted the image based upon a photograph I found on the internet:
My frame script wasn't working when I posted the image so I used a really poor substitute.
The actual painting is canvassed but unframed.
Here is a frame I made using a bit more time and care, and similar to the one she ordered:
I wish I could paint ... alas, not one of my talents.
