It is currently Thu Nov 19, 2026 5:20 am
 Post subject: Interweaved Ribbon.
PostPosted: Sat Oct 02, 2010 7:58 pm  (#1)
Still liking the gradient along selection plugin. Created the seamless texture (not as clean as I wanted it to be) and then the sphere (like you all know I like to do). :)
 Post subject: Re: Interweaved Ribbon.
PostPosted: Sat Oct 02, 2010 9:04 pm  (#2)
That is very cool. I love the sphere. I'd like to know what you used to make it seamless.
PostPosted: Sat Oct 02, 2010 9:17 pm  (#3)
That is totally awesome!! I am floored!
My Sigs = My Photos
PostPosted: Sat Oct 02, 2010 11:05 pm  (#4)
Thanks all. To O, I first started off with the Loop selection and ran the py script. I then dup, and half-wrapped the base layer and made a copy of the base layer to the Top layer (for a total of three layers). I then selectively erased alternating sections on the Top layer to get the interleave. I then merged visable, dupped, rotated 90º, copied the base layer to the Top layer and did a similar step as before for the more complicated result. :)
PostPosted: Sat Oct 02, 2010 11:59 pm  (#5)
I have to think about what you just said, Lyle. A little confusing, but maybe if I tried it, it would make more sense to me.
My Sigs = My Photos
PostPosted: Sun Oct 03, 2010 12:08 am  (#6)
It's all about the magic of erase throughs. Having a duplicate of the Top layer at the Base layer too makes it easier to erase those sections on Top where you want to. :)
PostPosted: Sun Oct 03, 2010 1:10 am  (#7)
It dawned on me afterwards, what you meant. I did something similar with a cube, some time ago.
and
My Sigs = My Photos
PostPosted: Sun Oct 03, 2010 1:12 am  (#8)
Excellent. Yeah; hard to explain, but not hard to do. Most of the time I run in to tuts that that author guesses is easy to explain but in execution it is hard to do. lol
PostPosted: Sun Oct 03, 2010 5:53 am  (#9)
I didn't understund a single step of the how to , but i suppose that follow with gimp opened will help
but what is a "loop selection " :gaah ?
Anyway the result are excellent :coolthup
PostPosted: Sun Oct 03, 2010 9:30 am  (#10)
I should of said that I started with creating a loop PC. lol
The half-wrap and erase though steps aren't easily outlined, but it is easy if you actually do it as PM did. :)
PostPosted: Sun Oct 03, 2010 1:24 pm  (#11)
I made the original loop, duplicated it and ran my switch sides script on it. Now I see where I nee to modify my switch side script to allow for alpha channel!
My Sigs = My Photos
PostPosted: Sun Oct 03, 2010 2:10 pm  (#12)
I just updated my script to switch the side of an image, to Ver 1.1, on the Plugin Registry. Here is the link if anyone want's it. http://registry.gimp.org/node/24403
My Sigs = My Photos
