It is currently Fri Nov 20, 2026 12:52 am
 Post subject: Magnifying Glass
PostPosted: Tue Nov 27, 2012 3:28 pm  (#1)
Hi, everyone!
GC-L&S-paperK1TE.7z [1.41 MiB]
Downloaded 848 times
Please, respect author's rights.
Edit. Uploaded the wrong image, now it's fixed. Also attaching xcf file of the handle, since it was done separately.
The original xcf was scaled down to 70%.
Magnifying Glass- HANDLE.xcf [202.07 KiB]
Downloaded 345 times
 Post subject: Re: Magnifying Glass
PostPosted: Tue Nov 27, 2012 5:02 pm  (#2)
Excellent job, I like the shadow effect in the magnifying glass.
PostPosted: Tue Nov 27, 2012 5:13 pm  (#3)
Really nice,the lighting and shadows as well as the highlight on the glass all looks good.
PostPosted: Tue Nov 27, 2012 5:28 pm  (#4)
Excellent, I could not say if it is a design or photo.
I think you should choose a license for your image, in this way people know what they should respect
PostPosted: Tue Nov 27, 2012 6:19 pm  (#5)
k1tesseraena: that's so perfect! well done!
PostPosted: Tue Nov 27, 2012 6:36 pm  (#6)
WOW!
PostPosted: Tue Nov 27, 2012 10:31 pm  (#7)
Thank you, everyone!
I've changed the image because initially uploaded the wrong one. Was in a hurry and just pasted 'new from visible' inside xcf
and that was with one extra layer, so the whole visible became 'bleached' and half of the shadows gone. Fixed it. Looks better now and
the way it was supposed to look.
The xcf, though, was/is right when you open it in GIMP.
Also added xcf of the handle. Actually the handle was the easiest part. Just making rectangular selections with rounded corners and adding
one of the he4rty's Crown Moulding gradients to metallic parts. I have a few real good paper textures in my texture library, they're all colored,
so I simply desaturated one of them and adjusted the curves.
The hardest part was definitely the shadow/lights masking of the lens surface and finding the right balance. All the other simple glossy tricks
learnt from Inkscape and are easy enough to replicate in GIMP. Scaled the image down to be more viewable in GC.
Took me about 1 hour to ponder the project and find the reference image, two more for drawing and tweaking it.
Have another project in mind - want to draw a book.
PostPosted: Tue Nov 27, 2012 11:13 pm  (#8)
what ???
you made that in Gimp ?
speechless :-O
how are you able to construct such a complicated gloss from scratch ??
EDIT: what is the name of the font, please ?
PostPosted: Tue Nov 27, 2012 11:53 pm  (#9)
@Esper
the name of the font is Typical Writer Thin.
I typed Light and shadows, duplicated text layer and cut it in two halves. Magnified text was made with Map>Map Object>Sphere.
At the end decided to add The Magic. Just the way i feel toward light and shadows in visual arts.
Gloss and shadows is a combination of few images I found with Bing Search. Like I said, I was looking at photographs
and other Magnifying Glass tutorials but neither one was good enough. One PS tutorial was particularly good, but
you can't follow it because PS is using layer styles and much better than GIMP gradient editors.
So I took the gloss design from it, although it's not identical intentionally. Seeing the pictures is enough for me to reproduce the effect.
Last edited by K1TesseraEna on Wed Nov 28, 2012 12:01 am, edited 2 times in total.
PostPosted: Tue Nov 27, 2012 11:58 pm  (#10)
It is just perfect!
PostPosted: Wed Nov 28, 2012 12:16 am  (#11)
Thank you, 2-ton!
Here's the Typical Writer Thin font
TYPIW___.7z [27.32 KiB]
Downloaded 172 times
PostPosted: Wed Nov 28, 2012 12:39 am  (#12)
Wow - that came out perfectly. Great effect! :D
PostPosted: Wed Nov 28, 2012 7:35 am  (#13)
I think I preferred the lighter version you posted, but I'm sure its all down to taste.
Here is a font I found to use when I had a go at creating a magnifying glass,
Font can be found here at dafont
PostPosted: Wed Nov 28, 2012 8:11 am  (#14)
Thank you, he4rty! I don't like the lighter version by one reason only - there is too much paper texture shown on the gloss,
which is not possible in real life. I sent files to my sister's computer and she said the same thing as you (she is an artist).
On my monitors it doesn't look that much darker, but I guess it all depends on monitor calibration, the topic that was discussed here recently.
PostPosted: Wed Nov 28, 2012 10:02 am  (#15)
you guys have got to stop putting up cool font links/downloads. My font folder is getting stuffed!!!!
PostPosted: Sun Dec 02, 2012 10:49 pm  (#16)
OK, after watching ccbar's recent wonderful animation I've made some adjustments -
changed 'magnified' text (basically by applying lens distortion plug-in and offsetting it according to real life optics behavior), also, following the advise from
many experts (including my sister), reduced amount of on-lens shadow. Got rid of paper texture just to get a better view of the applied changes.Image
PostPosted: Sun Dec 02, 2012 11:05 pm  (#17)
so realistic!
PostPosted: Mon Dec 03, 2012 2:30 am  (#18)
Picture perfect!
PostPosted: Mon Dec 03, 2012 9:07 am  (#19)
Stunning work!
PostPosted: Mon Dec 03, 2012 10:23 am  (#20)
I think K1TesseraEna is kidding us. That is a real photograph! :mrgreen:
Excellent design!
