It is currently Fri Nov 20, 2026 12:56 am
 Post subject: Detail
PostPosted: Fri Dec 14, 2012 9:25 pm  (#1)
:paint
it was much larger but i prefer to crop...
AAARGHH now i see 2 mistakes ,the render has too hard edges and i even made a error to crop the lower part...weird as mistakes pop out evident only after publishing,...
a quick correction
Ok Image
Before was
 Post subject: Re: Detail
PostPosted: Sat Dec 15, 2012 7:05 am  (#2)
Good composition. I find the background really lifelike.
Actually, though they basically are abstract, those three-dimensional fractals always remind and make me think of something real, a forest or underbrush in this case.
What program(s) do you use for creating them?
PostPosted: Sat Dec 15, 2012 7:23 am  (#3)
Wow, very nice PC
PostPosted: Sat Dec 15, 2012 11:17 am  (#4)
Mandelbulb3d , to not confuse with Mandelbulber ,you may found at www.frcyalforums.com, (there is also a dedicated board with a sticky with the new formula (the formula are updated in the program at each release, the sticky allow to update inbetween
and Yes can make quite interesting organic looking scenery , i had many in my gallery http://www.photocomix2.deviantart.com/
Wow, very nice PC
PostPosted: Sat Dec 15, 2012 11:54 am  (#5)
Nice! :bigthup
PostPosted: Sat Dec 15, 2012 12:15 pm  (#6)
Glad you like O !
Gino, i forgot that M3D is for windows but run really well in Linux with wine (or Crossover) and should work also with MAC (again with a emulator...it should be explaned in detail on the forum i linked )
PostPosted: Sun Dec 16, 2012 7:17 am  (#7)
Thanks, PhotoComix, for the explanation.
The 3D fractal art is a field that I never considered in depth so far, and now I am really curious to start exploring its potentials.
I have only encountered some problems with the link you posted (my browser says the site doesn't exist); however, via Google Search, I think I have found the right site, which might be this (I suppose):
http://www.fractalforums.com/
PostPosted: Sun Dec 16, 2012 7:23 am  (#8)
Sorry for the wrong link , here the exact link to the last version
http://www.fractalforums.com/index.php? ... ew;down=43
And if you want update the formula , get the zip here
(and yes, updating you will got a warning about overwriting files, and you should accept overwriting )
the zip is a attachment of the First message (so you don't need to read all the so long topic..)
http://www.fractalforums.com/index.php?topic=9810.0
PostPosted: Mon Dec 17, 2012 9:02 am  (#9)
Beautiful work as usual PC.
