sofasurfer wrote:
I am working on a project and I need to have 2 images joined. In the enclosed photos I need the badge superimposed on the document. I would like to have the badge, with the black areas removed, placed on the lower right corner of the document and taking a bit less than one forth of the document. I would like to see the document through the openings in the badge. I'd like it to look like the badge is lieing on the document if possible.
Thank you to anyone who can do this for me.
My own take...
1) restore badge to actual circle
2) cut out badge (color to alpha)
3) import document
4) scale down badge and move to position
5) rotate badge layer and apply slight perspective
6) add small drop shadow
PS: got the shadow on the wrong side. Putting it on the right side is left as an exercise to the reader (easy enough to fix given the XCF).
