It is currently Fri Nov 20, 2026 12:54 am
 Post subject: Skyscraper Rainbow
PostPosted: Sun Jan 06, 2013 6:23 pm  (#1)
I've always liked these types of shots.
I noticed 14 columns, double and twinned rainbows have 14 bands of color.
I used two layer modes, Grain merge (left group) and Soft light (right group).
Original Skyscraper photo
 Post subject: Re: Skyscraper Rainbow
PostPosted: Sun Jan 06, 2013 6:45 pm  (#2)
That creates a stunning vertigo effect. :hehe
PostPosted: Sun Jan 06, 2013 6:49 pm  (#3)
odinbc: that's really cool, kudos for the idea! how did you make the grading?
PostPosted: Sun Jan 06, 2013 7:25 pm  (#4)
I experimented with the Scissors tool but found the Free Select tool was better with the straight lines. I saved Channels for each column and then played with gradients and layer modes. The Gradient is FG to Transparent.
PostPosted: Mon Jan 07, 2013 4:16 am  (#5)
This is awesome. Stunning effect.
PostPosted: Mon Jan 07, 2013 1:48 pm  (#6)
I toyed with the idea of using a grayscale version (right), but stayed with the building reflection colors. It was a tossup which one has a better look.
PostPosted: Mon Jan 07, 2013 1:51 pm  (#7)
Really outstanding effect, Odin. My neck hurts from looking it up at it. :hehe
PostPosted: Mon Jan 07, 2013 2:10 pm  (#8)
Did you tried a grading rotated of 90° ?
(colours changing with the distance from the base of the building )
PostPosted: Mon Jan 07, 2013 2:21 pm  (#9)
Very good job. I like the idea of colouring the columns of the skyscrapers. :paint2
In which city is the one in the original photo located? It has every appearance of being infinitely tall. :shock:
PostPosted: Mon Jan 07, 2013 3:55 pm  (#10)
I know it's in New Orleans, Lousiana. USA. It looks like it could be One Shell Square, with the photo taken from the first roof. The photo I used has the top cut off, so it's hard to tell.
PostPosted: Mon Jan 07, 2013 4:10 pm  (#11)
I'm not sure what your technique is Photocomix, can you make an example?
