It is currently Fri Nov 20, 2026 3:31 am
 Post subject: a new painting by me
PostPosted: Sun Feb 10, 2013 9:20 pm  (#1)
just did this..took about 35 to 45 minutes...
 Post subject: Re: a new painting by me
PostPosted: Sun Feb 10, 2013 10:30 pm  (#2)
I liked the softness. Really an image that pleases the eye. :coolthup
bbbbbbbbbbbImage
PostPosted: Sun Feb 10, 2013 10:54 pm  (#3)
thanks
PostPosted: Mon Feb 11, 2013 3:45 am  (#4)
rdgracer71 wrote:
jut did this..took about 35 to 45 minutes...
Wow rdgracer71, you work fast I wouldn't know where to start! :bigthup
PostPosted: Mon Feb 11, 2013 5:02 am  (#5)
thanks. i just sat down and wasn't even gone do a painting. it just happen. i didn't even plan it out. i tried to keep it simple once i started. i kinda like it and often i don't like my work that much...thanks for the views.
PostPosted: Mon Feb 11, 2013 12:41 pm  (#6)
rdgracer71: that looks good! i like the moss in the foreground, it has so much moss character even if it was very quickly made. i could never make something so quickly, i'm a very slow worker, so i'm impressed :).
PostPosted: Mon Feb 11, 2013 12:44 pm  (#7)
thats nice racer !
what brushes did you use ?
PostPosted: Mon Feb 11, 2013 12:52 pm  (#8)
I love this painting and from what I see, you are learning a lot about color perspective. I can really tell the difference between this one and your earlier ones. When I sit away from the pc I can see the depth.
KUDOS --> Keep up the good work.
 Post subject:
PostPosted: Mon Feb 11, 2013 3:28 pm  (#9)
Beautiful. Very calming and, just beautiful!!
PostPosted: Mon Feb 11, 2013 4:14 pm  (#10)
Esper wrote:
thats nice racer !
will post them soon...
 Post subject: Re:
PostPosted: Mon Feb 11, 2013 4:16 pm  (#11)
thank you.. it does indeed look like a peaceful day doesn't it... :) :)
PostPosted: Mon Feb 11, 2013 4:19 pm  (#12)
thank you for your kind words. you don't know what this means to me.. and again thank you. :sneak
PostPosted: Mon Feb 11, 2013 7:59 pm  (#13)
Esper wrote:
thats nice racer !
here are the brushes i used. they are simple ones. theres one that is not showing in the pic below. it's the circle brush. i used the circle brush to make the clouds along with the smudge tool and to also draw the mountains with. i drew the outline of the mountains with the circle tool and just filled them with the bucket tool. to make the grass i used the one on the bottom of the this pic along with the airbrush tool and lowering the rate and pressure of the airbrush tool and just change different colors of green and browns. thats pretty much it. the fog or mist at the base of the mountains were made with the brush at the top of my picture ,with the airbrush tool and lowering the rate and pressure. and that's pretty much all i used.
PostPosted: Tue Feb 12, 2013 7:25 am  (#14)
That's a lovely peaceful painting. I like the texture in the grass.
PostPosted: Tue Feb 12, 2013 8:18 pm  (#15)
How pretty! :D
PostPosted: Tue Feb 12, 2013 11:33 pm  (#16)
Nice job on the atmosphere! Gives a good sense of distance :D
PostPosted: Wed Feb 13, 2013 12:20 am  (#17)
thanks guys. so far i think this is the most comments i have had on a piece of work...thanks
PostPosted: Sat Mar 23, 2013 12:56 am  (#18)
i truly enjoy painting with my gimp. and i have thought about starting a series of how to videos on youtube to show step by step how i do my paintings. In other words i would use a screen recorder to record me doing a painting from start to finish and it would show how i do my paintings. But i'm not sure yet if i am gonna do it or not.
PostPosted: Sat Mar 23, 2013 5:17 am  (#19)
Good luck if you do. I would love to do video tutorials but my computer can't handle running two programs at once.
PostPosted: Sat Mar 23, 2013 11:18 am  (#20)
Very nice painting and good choice of colors. I also really like the softness of the clouds. :)
cron
