It is currently Fri Nov 20, 2026 2:27 am
Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2, 3  Next
 Post subject: Smokescreen
PostPosted: Tue Feb 12, 2013 5:24 pm  (#1)
i think i got tricked by K1te again :mrgreen:
he casually dropped a tutorial, making me believe it means nothing at all, while complimenting me on my tutorial
of course i took the bait - the innocent non-smoker i am :?
that wasnt easy to replicate - and i still dont know how they get the blue glowing light effect with dodge, so my smoke is greyish-white
PS tutorial here:
http://abduzeedo.com/smoke-type-photoshop-10-steps
 Post subject: Re: Smokescreen
PostPosted: Tue Feb 12, 2013 5:44 pm  (#2)
Very cool job Esper.
PostPosted: Tue Feb 12, 2013 6:04 pm  (#3)
Nice job .
PostPosted: Tue Feb 12, 2013 6:15 pm  (#4)
esper: nice smoke! it's really irritating about that coloured light effect, though - in the tutorial it's like there's a change of saturation as well as a change of value and i don't see anything like that ever when i use the dodge layer mode.
PostPosted: Tue Feb 12, 2013 6:31 pm  (#5)
Maybe it is from the filter in PS. It says "Blend Mode to Color Dodge" Gimp doesn't have a color dodge unless I am reading it wrong. Do you think that is where they got the blue?
PostPosted: Tue Feb 12, 2013 7:10 pm  (#6)
no molly, but as Ronounours said in this thread:
viewtopic.php?f=28&t=6399
Ronounours wrote:
Color dodge and burn are named simply dodge and burn.
and i tried soft dodge from G'MIC as well
so either Ronounours is wrong or soemhting else is going on, that i dont see
PostPosted: Tue Feb 12, 2013 7:14 pm  (#7)
shucks. I like yours anyway. I think it looks like real smoke more than the blue PS one does.
:teeth
PostPosted: Tue Feb 12, 2013 7:49 pm  (#8)
i cant replicate it in PS either..... :hoh
but PS sucks anyway :rofl
PostPosted: Tue Feb 12, 2013 8:16 pm  (#9)
Looks very smokey. ;) :P
PostPosted: Tue Feb 12, 2013 8:34 pm  (#10)
That is a conspiracy theory in the making!
The same here - I could not replicate it in PS6, I made an attempt in GIMP about 2-3 weeks ago and ended up with this
I think there is a step or two missing in that tutorial.
PostPosted: Tue Feb 12, 2013 8:37 pm  (#11)
heres how i made the smokey text:
01. make weird text as in this tutorial
viewtopic.php?f=23&t=6406
in this case it can be a bit blurry - we want that
02. duplicate text layer and apply Motion Blur on duplicate
align MotionBlurred layer a bit
03. set MotionBlurred text to 'Difference' and without the BG, use 'New from Visible'
04. apply 'Filters -> Distorts -> 'Ripples'
once vertical and once horizontal
05. duplicate twice, set upper two layers on 'Screen' and the first Smoke-layer to 'Saturation' 30%
offset 'Screen' layers a bit
PostPosted: Tue Feb 12, 2013 11:00 pm  (#12)
My Poor effort below↓ a great tutorial Esper and i think you've been had by K1te again :hehe :rofl
PostPosted: Wed Feb 13, 2013 1:53 am  (#13)
Here's my quick attempt.
PostPosted: Wed Feb 13, 2013 5:04 am  (#14)
i tried this and nothing worked. my text looked nothing like what you made. your steps are confusing to me.
PostPosted: Wed Feb 13, 2013 5:29 am  (#15)
@Esper, I like that smoky look a lot. I made your tute into two parts in one pdf so I could have them all in one place if anyone is interested, it is posted below. I will try it later too.
Espers Warped Text and Smoke Screen Tutorial.pdf [513.54 KiB]
Downloaded 171 times
PostPosted: Wed Feb 13, 2013 5:35 am  (#16)
Good effect, i will try it. :coolthup
PostPosted: Wed Feb 13, 2013 5:45 am  (#17)
http://www.gimpchat.com/viewtopic.php?f=23&t=6406
It shows in your screen shots that you did them both vertical. Is that just the wrong scr shot?
PostPosted: Wed Feb 13, 2013 7:05 am  (#18)
thats a mistake, the one with Amplitude 9 is the vertical and the other one is horizontal
but its not really a tutorial, just a quickinfo for the basic steps how i made it, you have to make it your own
maybe the waved text could be improved, but Ripple was the best filter i could find for the job
EDIT: i updated the screenshot
PostPosted: Wed Feb 13, 2013 7:06 am  (#19)
Thanks Esper
PostPosted: Wed Feb 13, 2013 10:23 am  (#20)
Thought I'd have a try but all a bit rushed.
