It is currently Fri Nov 20, 2026 2:27 am
 Post subject: Reflective chrome text.
PostPosted: Wed Feb 13, 2013 2:02 am  (#1)
Just felt compelled. lol
Started out taking the flat layer result from logo>glossy. Used many G'MIC presets such as Local Orientation, Anistotrophic, and Tone map presets, but also cheated a little and used Artshop's Irridescent filter (works great in GIMP via PSPI). Gradient mapped using a metallic gradient and also added Sparkle filter and voila. :)
 Post subject: Re: Reflective chrome text.
PostPosted: Wed Feb 13, 2013 4:05 am  (#2)
I love it, you could use that technique for a new G'MIC logo!
PostPosted: Wed Feb 13, 2013 4:32 am  (#3)
I love it too Lyle. You should try that same effect on a shiny new car. It would be cool.
Fixer-Uppers
PostPosted: Wed Feb 13, 2013 5:41 am  (#4)
Oh wow, this looks like the letters are Autobots / Decepticons.
PostPosted: Wed Feb 13, 2013 7:00 am  (#5)
it looks very artistic and special (as in rarely seen before)
tutorial next ? :mrgreen:
PostPosted: Wed Feb 13, 2013 9:47 am  (#6)
Looks really good, very shiny and reflective.
PostPosted: Wed Feb 13, 2013 11:33 am  (#7)
Really nice Lyle
PostPosted: Wed Feb 13, 2013 12:51 pm  (#8)
Wow! That looks nice.
Alan
PostPosted: Wed Feb 13, 2013 3:12 pm  (#9)
lylejk: wow, that's cool! i like what happened to the background, it looks like glass.
PostPosted: Wed Feb 13, 2013 3:19 pm  (#10)
Thanks for all the comments. Only had 2 hours of sleep and going to take a cat nap soon, but again, the process is quite simple. The link to Artshop's Irridescent filter is below (been shared here I believe before, but I can't find that thread; again works great with PSPI). :)
http://www.thedigitalartshop.com/filter ... ug-in.html
PostPosted: Wed Feb 13, 2013 3:25 pm  (#11)
I know you don't do tutorials, but sure would love one for this look! I don't know if I can use pspi with mcgimp.
EDIT: link to tutorial here Reflective Chrome Text-lylejk
PostPosted: Thu Feb 14, 2013 3:15 am  (#12)
I could not follow all the steps.
Not used the Iridescent filter and have not found the gradient map.
Yet the result was interesting
bbbbbbbbbbbImage
PostPosted: Thu Feb 14, 2013 4:58 am  (#13)
lylejk: you wrote a tutorial - that makes you officially not lazy :hehe ! thanks for the tute, it was fun to try.
akros: looks good! you find gradient map under colours -> map -> gradient map.
i don't want to use any filter i need pspi plug-in to use, so i tried to give my text some iridescent effects using just recoloured copies of the text layer and curves and layer modes - didn't work as well as i'd hoped, but just like akros i think i got an interesting result anyway. i'll play with this some more and see if i can get it a bit smoother.
PostPosted: Thu Feb 14, 2013 6:57 am  (#14)
Since it was in my GIMP gradient directory, I had assumed that it was a part of GIMP distribution but I could be wrong; attached the gradient Akros; just paste it in your user gradient directory (mine again was actually in my GIMP main gradient directory). :)
Metallic_Something.ggr [865 Bytes]
Downloaded 101 times
PostPosted: Thu Feb 14, 2013 7:01 am  (#15)
Great result AnMal, but again, I'm a filter guy. lolol
PostPosted: Thu Feb 14, 2013 6:18 pm  (#16)
AnMal, I just searched in filters and G'mic. Thanks for the tip! :tyspin
AnMal, but his was very similar to the tutorial, you may have discovered another way to get the same result! :clap Perfect!
bbbbbbbbbbbImage
PostPosted: Thu Feb 14, 2013 6:25 pm  (#17)
There really was not in my directory. But now ok!
Thx Lyle!! :bigthup ;)
bbbbbbbbbbbImage
PostPosted: Thu Feb 14, 2013 7:03 pm  (#18)
This is embarrassing. Great job Lyle!
PostPosted: Thu Feb 14, 2013 11:22 pm  (#19)
Hey Draconian, how are you? Lyle did a nice job but we all learn from your guidance, my friend :bigthup
