It is currently Thu Nov 19, 2026 7:00 am
 Post subject: Dog tags in GIMP
PostPosted: Thu Nov 04, 2010 2:56 am  (#1)
This was a lot of fun. I started out using images of a chain and dog tag, and decided "what the heck, be an artist, and make your own image". So, here is my first draft at mimicking stamped font (using Rob A's Chisel script).
 Post subject: Re: Dog tags in GIMP
PostPosted: Thu Nov 04, 2010 4:26 am  (#2)
Wow that is sooooo real looking. I love it. The metal looks so real with the blue tints. very well done mahvin.
"step by step tute would sure be nice" :wh
PostPosted: Thu Nov 04, 2010 11:34 am  (#3)
Very nice =)
Love the metal gradient.
PostPosted: Thu Nov 04, 2010 5:21 pm  (#4)
@Molly: the fine print on making a tutorial needs to be larger (I didn't see it the first time I read it, haha). I'll try to create a tutorial to follow, soon.
@Rod: I think the gradient is part of the GIMP package (named "metallic something"). That's the actual name, not me guessing. :)
Thank you both for your compliments. :)
PostPosted: Thu Nov 04, 2010 9:54 pm  (#5)
did you make the chain yourself? The whole pic is very good, and a tut would be fun to try.
PostPosted: Thu Nov 04, 2010 11:09 pm  (#6)
Yes, I made the chain, too. I created a brush of the one chain and ran it on stroked path. I'll try and get a tutorial up for it soon (maybe Sunday).
PostPosted: Thu Nov 04, 2010 11:23 pm  (#7)
Like the tag Mahvin; really does look realistic. As a side note, I recently visted your site (don't know why I haven't before) and do like that 3D gear tut that you have there too. :)
PostPosted: Sat Nov 06, 2010 9:54 am  (#8)
Didn't O make a bead brush? That would work awesome for this tut. =)
PostPosted: Sat Nov 06, 2010 1:21 pm  (#9)
Would someone be interested in trying the Chisel script on my dogtag, with the same settings as in mahvin's tute? I have tried it too many times to count. I merged the two texts, tried them one at a time. Finally came to the conclusion it is just my pc or me...
molly-tag.xcf [124.98 KiB]
Downloaded 153 times
PostPosted: Sat Nov 06, 2010 2:29 pm  (#10)
http://www.mahvin.com/images/molly-tag2.xcf
All I did was blur the newly formed chisel layer after running the chisel script, about 7 px. You can check the layer modes. I probably said "blur the text layer" but I meant the new layer created from the text "after" you run the chisel script. Not the original text layer.
PostPosted: Sat Nov 06, 2010 3:32 pm  (#11)
wow that looks really good. I will try to do it again they way you said. If it doesn't work then it has to be my GIMP somehow.
thanks Mahvin....
