It is currently Fri Nov 20, 2026 3:32 am
 Post subject: Symmetric drawings
PostPosted: Fri Mar 29, 2013 2:34 pm  (#1)
Here's some more stuff I've done using Krita's symmetry tools. Didn't want to flood Griatch's thread with them so made my own...
This first one doesn't use sketch brush, just regular inks (and paint! in colour!) and the dynamic drawing tool. I made it recently...
These two are just doodles...
 Post subject: Re: Symmetric drawings
PostPosted: Fri Mar 29, 2013 2:35 pm  (#2)
Here's also an older piece, showing use of partial symmetry...
PostPosted: Sat Mar 30, 2013 6:27 am  (#3)
Excellent work dd. I particularly like the first "doodle". When you are not bogged down with specifics your imagination gets a chance to be spontaneous.
PostPosted: Sat Mar 30, 2013 12:26 pm  (#4)
Yeah. There's this certain drawing technique that sort of depends on the imagination of the viewer more so than the artist. The human mind has such pattern recognition capabilities it's amazing what it can do when you give it free hands.
I once crumpled an A4 paper into a ball and then opened it. Then I drew all the things I saw in the wrinkles, it took some 8 hours and the end result was amazing, you could "see" new things in it all the time... too bad I don't have it anymore.
PostPosted: Sun Mar 31, 2013 2:42 am  (#5)
DD - excellent work.
PostPosted: Sun Mar 31, 2013 7:09 am  (#6)
Cool technique. :hi5
PostPosted: Sun Mar 31, 2013 5:46 pm  (#7)
dd: :wow these are really great! i love them all, but the top one and the first doodle were my favourites. i also really like the idea of crumpling up an A4 and drawing what you see in it, i'll have to try that some time!
PostPosted: Mon Apr 01, 2013 5:00 am  (#8)
It occurs to me that you could probably try the same technique digitally. Use some combination of noise filters and textures to get some kind of complex random pattern and start drawing on it...
PostPosted: Mon Apr 01, 2013 5:54 pm  (#9)
dd: that's a fun idea, i'll definitely give it a try :)!
PostPosted: Tue Apr 02, 2013 1:19 am  (#10)
Fun designs, dd. :) One can really spend a lot of time just exploring mirror functionality.
As for crumpling the paper, getting inspiration out of semi-random structures sounds similar to how Alchemy works. I never really got into Alchemy but I know some artists swear by it.
Griatch
PostPosted: Tue Apr 02, 2013 6:34 am  (#11)
That's a fantastic idea. I might give it a try one day. Molly once did a thread on painting images into textures. I'll see if I can find it - it's a similar idea.
cron
