It is currently Fri Nov 20, 2026 4:57 am
 Post subject: Getting closer to the Doyle.
PostPosted: Sat Apr 06, 2013 9:42 pm  (#1)
Looks like Droste can actually do Doyle better then I though. Clicked the show both poles option and fiddled with a few more settings and voila. Did convert the flat white disk to the marbles using Plastic or Glass Script-fu and a few G'MIC presets. :)
 Post subject: Re: Getting closer to the Doyle.
PostPosted: Sat Apr 06, 2013 9:46 pm  (#2)
Do you think this could be applied to text?
PostPosted: Sat Apr 06, 2013 10:17 pm  (#3)
Really nice
PostPosted: Sun Apr 07, 2013 2:38 am  (#4)
lylejk: :jumpclap :hi5 that's really cool! and do you remember what presets you used in making the glass bubbles?
PostPosted: Sun Apr 07, 2013 11:48 am  (#5)
Cool ! i often use the option to show both poles ,but here there is the plastic look and the depth to enhance the effect ,nice and clean
PostPosted: Sun Apr 07, 2013 4:34 pm  (#6)
Thanks for all the comments; apologize for not responding earlier, but, I had to take a boot camp and then a test in order to keep my job (and I passed with flying colors. :) ). Anyway, check to post below for some hints; the glassy effect, again, used Graechan's Plastic or Glass Script-fu mainly. :)
http://gimpchat.com/viewtopic.php?f=23&t=3941
PostPosted: Thu Apr 11, 2013 9:33 am  (#7)
Well, this is as close as I could come to compacting the spaces and I had to do some editing of the Mathmap Droste preset itself in order to achieve this. Still not 100% happy, and, if I try to add Graechan's shinyness to this one, it converts to a blob. lol
PostPosted: Thu Apr 11, 2013 2:37 pm  (#8)
No Gram; the result is straight out of Mathmap (except the rounding of the balls; used G'MIC, and several other things to get that). Started out with just white disks. I'm going to experiment a little more to see if I can get the 2 poles closer together, but a little bushed right now. :)
PostPosted: Thu Apr 11, 2013 5:02 pm  (#9)
Still having fun. :)
PostPosted: Thu Apr 11, 2013 6:32 pm  (#10)
Again, I edited the Droste preset (set both the starting level and number of level ranges to 100 (the defaults are way too small). If you choose the show poles option, Number of Levels equals 2*Starting Level. try 40 for Number of levels and 20 for Starting Level.
And why not some more madness too. lol
PostPosted: Thu Apr 11, 2013 8:44 pm  (#11)
Can't have too many smile's Gram. ;)
