It is currently Fri Nov 20, 2026 5:01 am
 Post subject: Gimp Chat Dock Icon...
PostPosted: Sat Apr 20, 2013 1:23 pm  (#1)
Here's the dock icon that I made and use for GC.
 Post subject: Re: Gimp Chat Dock Icon...
PostPosted: Sat Apr 20, 2013 3:41 pm  (#2)
cool wallace, I didn't know you could edit those icons.
PostPosted: Sat Apr 20, 2013 9:21 pm  (#3)
How do you use your own icon?
PostPosted: Sat Apr 20, 2013 10:05 pm  (#4)
What is a dock icon? I love what you made but would like more information about its intended use. :hehe
PostPosted: Sat Apr 20, 2013 10:10 pm  (#5)
Normally (in windows anyways) you can right click any application and select change to select a different icon.Then just link to the custom one and select apply or ok.
I am not sure about Mac or Linux distros.
I am assuming Wallace created this one for RocketDock or a similar app?
PostPosted: Sat Apr 20, 2013 10:12 pm  (#6)
Thanks Rod. Yes, there is a similar application in Linux for using custom icons.
PostPosted: Sun Apr 21, 2013 4:42 am  (#7)
Here is one to try in GIMP...Creating your custom Icon
PostPosted: Sun Apr 21, 2013 5:24 am  (#8)
Yes, it's basically the same in Linux, depending on the Desktop Environment you use.
Cario Dock is one of the more popular docking apps in Linux, allowing the user to specify a custom icon for any application launcher on the dock. There is really no need for a reflection in the icon, as a reflection is normally an option generated by the docking app itself.
Due to scalability, I prefer to use svg images as custom icons.
PostPosted: Sun Apr 21, 2013 5:48 am  (#9)
Thank you Tux.
PostPosted: Sun Apr 21, 2013 3:28 pm  (#10)
Here's a screen shot of my desktop, with some of the icon that I made with Gimp highlighted.
