It is currently Fri Nov 20, 2026 4:58 am
 Post subject: Iron Man Armour Text
PostPosted: Fri Apr 26, 2013 7:08 am  (#1)
Hardest work on text effects ever!
Inkscape->Shapes
GIMP-> Effects
:mrgreen:
 Post subject: Re: Iron Man Armour Text
PostPosted: Fri Apr 26, 2013 7:14 am  (#2)
Awesome some. Combine that with Photofont (see this thread: http://www.gimpchat.com/viewtopic.php?f ... 542#p44619) and you might have something there Chris. :)
PostPosted: Fri Apr 26, 2013 7:17 am  (#3)
Awesome some. Combine that with Photofont (see this thread: viewtopic.php?f=12&t=3542#p44619) and you might have something there Chris. :)
hrmmmm :hehe
Yes if you make the letters i will make the photofont (PHF file) for you. :bigthup
PostPosted: Fri Apr 26, 2013 8:46 am  (#4)
Should have linked this one; earlier linked where Photofont, I believe, was first introduced. Rod did a fantastic job with the thread below. :)
http://www.gimpchat.com/viewtopic.php?f ... ont#p47462
PostPosted: Fri Apr 26, 2013 9:43 am  (#5)
Awesome work Chris. I love it.
PostPosted: Fri Apr 26, 2013 10:26 am  (#6)
Fantastic Chris...your work is awesome.
PostPosted: Fri Apr 26, 2013 10:51 am  (#7)
Amazing, nice work man.
PostPosted: Fri Apr 26, 2013 1:49 pm  (#8)
Superb.
PostPosted: Fri Apr 26, 2013 3:17 pm  (#9)
That's really nice how the top parts are sharply beveled and the bottoms are rounded. And the little metal type pieces are a nice addition.
I tried to do that. I created a linear selection using Quick Mask and ran the curves a few times. Once to round the bottom gradient, and then a random curvy type curves on the upper half first then the bottom half after inverting the selection.
PostPosted: Fri Apr 26, 2013 8:14 pm  (#10)
hrmmmm :hehe
CrisF a photofont would look cool if used with this text or a font made similiar to IronCladBoltedRaised
It's a free font from somewhere (I forgot where) so I'll post the Zip
IronCladBolted.zip [59.94 KiB]
Downloaded 101 times
PostPosted: Fri Apr 26, 2013 8:32 pm  (#11)
Wau, nice work! :D
PostPosted: Sat Apr 27, 2013 2:16 pm  (#12)
Thanks for your comment! :jumpclap
I can post a little howto. I must find a way out to create this effect easy.
When the set is ready, you can create a bitmap font, Rod. ;)
PostPosted: Sun Apr 28, 2013 10:25 am  (#13)
Sounds great.Just let me know. :) :bigthup
PostPosted: Mon Apr 29, 2013 6:09 am  (#14)
The bitfonter software looks very interesting, is there a similar software alternative?
Dont want to buy it.
Rod, if you want to convert some bitmap alphabets from me, you can found some on my blog:
http://chrisdesign.wordpress.com/2007/1 ... downloads/
PostPosted: Mon Apr 29, 2013 10:02 am  (#15)
Okay! :)
This one (Giraffe) wouldn't work.
http://www.mediafire.com/?5wbfdnlsk2l
Invalid or Deleted File.
Keep in mind that the bigger you make these for me the bigger they will open in Photofont (higher res)
I will see what i can do for you. :bigthup
Chromium Chris - res - 480 (300 norm)
I need to fix the order.For some reason it didn't start at 0041 (A) like it should have.
But all the characters work. :) Basically right now you would type J for C - I for B, and so forth (7 characters off).
I will have to do it the slow way and add them one at a time.May take a while. :)
Example
JNXRY = CHRIS :rofl
The smaller letters (non-caps) are closer as a typed d will produce c
So dijst will produce chris
