It is currently Fri Nov 20, 2026 4:58 am
 Post subject: Grassy Text
PostPosted: Sun Apr 28, 2013 12:44 pm  (#1)
Almost time to mow that lawn! :hehe
 Post subject: Re: Grassy Text
PostPosted: Sun Apr 28, 2013 12:47 pm  (#2)
Pretty cool, Rod. Do I detect clover leaves or is it just my imagination?
PostPosted: Sun Apr 28, 2013 1:00 pm  (#3)
Actually its the ~"coughpotleafcough"~ in gimpressionist. :rofl
PostPosted: Sun Apr 28, 2013 1:11 pm  (#4)
And I lit that for you...
PostPosted: Sun Apr 28, 2013 7:03 pm  (#5)
:rofl
PostPosted: Sun Apr 28, 2013 9:12 pm  (#6)
what is that I smell. hahahahahaha.....where is the candy?
PostPosted: Sun Apr 28, 2013 9:51 pm  (#7)
Rod if you save the settings as a preset then you could script it
PostPosted: Sun Apr 28, 2013 10:07 pm  (#8)
I got the munchies!
PostPosted: Sun Apr 28, 2013 10:55 pm  (#9)
PostPosted: Sun Apr 28, 2013 11:45 pm  (#10)
lol, what have I started. You guys crack me up.
PostPosted: Mon Apr 29, 2013 1:23 am  (#11)
Made in Furry Script with Maple leaves pattern
As soon as I saw the picture I thought 'Furry Script' Rod
PostPosted: Mon Apr 29, 2013 1:41 am  (#12)
Plushiest grass ever. Perfect for picnic grass.
PostPosted: Mon Apr 29, 2013 2:44 am  (#13)
Thank you ek22. Tried it with another green pattern and it turned out the same. Unless the 'fur' was only made from the two colours I picked.
PostPosted: Mon Apr 29, 2013 5:34 am  (#14)
sallyanne - Isn't there a box you need to check to enable the script to use patterns rather than gradients?
PostPosted: Mon Apr 29, 2013 6:50 am  (#15)
Only thing I can see is the ability to make the background 'pattern, colour, gradient or none'. Nothing to check. The text color and mottling colour can also be changed.
EDIT: except - keep the layers.
PostPosted: Mon Apr 29, 2013 8:20 am  (#16)
Now we need a "passing out candy" emoticon. :lol
Graechan here are the settings and the brush (not sure if this brush is default in gimp lol).
UHOH! - The extension pgm is not allowed.
I attached a zip. :bigthup
settings
Preset
desc=Makes a grass effect
name=Grass-Text
orientnum=4
orientfirst=0.000000
orientlast=60.000000
orienttype=0
sizenum=7
sizefirst=7.000000
sizelast=10.000000
sizetype=2
brushrelief=12.000000
brushdensity=20.000000
brushgamma=1.000000
brushaspect=0.000000
generalbgtype=1
generaldarkedge=0.100000
generalpaintedges=1
generaltileable=0
generaldropshadow=0
generalshadowdarkness=20.000000
generalshadowdepth=10
generalshadowblur=4
devthresh=0.100000
paperrelief=0.000000
paperscale=30.000000
paperinvert=0
paperoverlay=0
selectedbrush=Brushes\leaf01.pgm
selectedpaper=Paper\defaultpaper.pgm
color=000000
placetype=0
placecenter=0
numorientvector=1
orientvector=0,0.500000,0.500000,0.000000,0.000000,1.000000,1.000000,0
orientangoff=0.000000
orientstrexp=1.000000
orientvoronoi=0
numsizevector=1
sizevector=0,0.500000,0.500000,50.000000,1.000000
sizestrexp=1.000000
sizevoronoi=0
colortype=0
colornoise=0.000000
You need to use a linear gradient top to bottom.
Then run Gimpressionist
Then use noise/spread-10
Then run the Gimpressionist filter again. :bigthup
Then noise>RGB noise - independent RGB - 0.20 for all color values - alpha 0
Drop shadow - 4, 4, 15
Results -
I may have the size too small for the brush , and noise RGB noise can be tweaked.You can experiment though. :tyspin
leaf01.zip [18.04 KiB]
Downloaded 62 times
PostPosted: Mon Apr 29, 2013 9:08 am  (#17)
That look lovely, time for a picnic!
PostPosted: Mon Apr 29, 2013 9:30 am  (#18)
Thank you Odinbc. It did turn out well.
I didn't use GIMPressionist like Rod originally did so I doubt it was from the leaves though. The script I used only has pattern for the background. I also picked two different greens for the text I guess that and the Furry Script did it.
PostPosted: Mon Apr 29, 2013 9:52 am  (#19)
That looks really good, sallyanne. Almost time to mow it. :mrgreen:
