It is currently Fri Nov 20, 2026 4:58 am
 Post subject: Vibrant color ring GIMP vs PS
PostPosted: Fri May 03, 2013 3:15 am  (#1)
Hi all,
I watched a tutorial on youtube here for designing a vibrant color ring. I new right away, this could be possible in Gimp, and this is my try.
I achieved this by drawing circles, cutting them in appropriate sushi shapes, re-positioning and rotating them etc:
GIMP rules!
vibrant_color_ring.xcf [614.49 KiB]
Downloaded 147 times
 Post subject: Re: Vibrant color ring GIMP vs PS
PostPosted: Fri May 03, 2013 3:20 am  (#2)
I like that.
PostPosted: Fri May 03, 2013 3:44 am  (#3)
Hi Molly,
Thanx. it is more complicated from PS's perspective, but the process I used was super simplified in GIMP; "If all that matters is the result." Ha ha !!!
PostPosted: Fri May 03, 2013 3:58 am  (#4)
I just looked at your layers, how did you get that second color in, you started with two gray shapes, then you got two white ones in to for the circle. I can't see how you did that.
PostPosted: Fri May 03, 2013 6:26 am  (#5)
I actually ended up with four layers each with a cresent shape and I chose different color for each of them. I then merged the first two layers and also merged the third and fourth layer to remain with only two layers. I then picked the blend tool for the gradient colors and applied them on the two layers in alternating direction.
PostPosted: Fri May 03, 2013 6:37 am  (#6)
It looks like a multi-fruit flavoured Polo. I like it a lot though it makes me hungry looking at it. Nice work.
PostPosted: Fri May 03, 2013 6:53 am  (#7)
What ever you did, that is totally super cool. I looked at your layers in the xcf file and can't figure out what you did. I love it!!!
I found the YouTube video of it and after watching it I felt a bit stunned. However, you translated it into Gimp in what sounds like a much more compact and efficient way. Yours is prettier, too. Colors more vibrant.
https://www.youtube.com/watch?v=XghxY-OxHSo
PostPosted: Fri May 03, 2013 10:40 am  (#8)
Really nice.
PostPosted: Fri May 03, 2013 12:23 pm  (#9)
It would make a cool new Gimp color pallet. :bigthup
PostPosted: Fri May 03, 2013 12:26 pm  (#10)
josephbupe: that's stunning! i agree with O, looks much better than the one made after the ps tutorial. and i couldn't figure out how you made it either. tutorial?
PostPosted: Fri May 03, 2013 1:30 pm  (#11)
Way too cool result Joseph. Thanks for sharing. :)
PostPosted: Thu May 09, 2013 9:31 pm  (#12)
Really looks cool! And I like to see when Gimp does better than PS ;).
Could you please post a tutorial how you did the ring?
