It is currently Fri Nov 20, 2026 5:02 am
 Post subject: Laced Rose.
PostPosted: Wed May 08, 2013 2:25 pm  (#1)
ref: http://www.fontplay.com/freephotos/seve ... 406-03.jpg
Had an epiphany (used G'MIC's Edges Offset in creative ways along with G'MIC's Isophots on a separate layer) and voila, some rosy lace. lol
 Post subject: Re: Laced Rose.
PostPosted: Wed May 08, 2013 2:29 pm  (#2)
Hey that is very cool Lyle. :)
PostPosted: Wed May 08, 2013 2:34 pm  (#3)
gothics would love it ! ;)
nice result, not sure what one could do with it art-wise
PostPosted: Wed May 08, 2013 2:51 pm  (#4)
That goes for most of my posts Esper. lol
Thanks for the comments too Rod. :)
PostPosted: Wed May 08, 2013 3:07 pm  (#5)
OK Esper; how about a possible candidate for guilloche. :)
PostPosted: Wed May 08, 2013 4:42 pm  (#6)
Thanks Gram. :)
PostPosted: Wed May 08, 2013 5:23 pm  (#7)
Loving the rose.
PostPosted: Wed May 08, 2013 11:08 pm  (#8)
Lyle My favorite is the guilloche Image
PostPosted: Wed May 08, 2013 11:30 pm  (#9)
I tried to duplicate but could not get that Lyle magic ingredient
PostPosted: Wed May 08, 2013 11:37 pm  (#10)
Very nice Rose
PostPosted: Thu May 09, 2013 12:25 am  (#11)
Thanks for the comments folks.
Here's what I do Graechan; I set the Active and below option in G'MIC. I first duplicate, then run the Edges Offset on the base layer. I then click on the Top layer and run the same preset (same parameters again) and set the top layer to darken and merge down (both layers get operated on since the settings in G'MIC; kills two birds with one stone; the base, of course, gets run again). Now I invert this result and copy it; it is my mask. I re-open the target image again, and add a mask layer and paste it. Another step that I didn't share to give a more illustrated result, is to open the target image yet again and dup, run Wavelet denoise (see my settings below) and set the result to Grain extract and merge down. I then do an autolevel on this result, then run Anisotrophic filter (fake smudge preset mention too many times here already) and copy this result above the masked layer created and set it to Grain merge. Dup/blend the top layer until happy then merge all visable. Now I create a base fill of lighter then black (not too light though; to taste) and flatten. I then colorize the result. :)
PostPosted: Thu May 09, 2013 5:57 am  (#12)
Beautiful Rose Lyle.
PostPosted: Thu May 09, 2013 9:25 pm  (#13)
Getting very close Gram; I believe the illustration step will get you there. :)
