It is currently Fri Nov 20, 2026 6:14 am
 Post subject: Wicker
PostPosted: Thu May 09, 2013 10:42 pm  (#1)
Adding Rodilius to the lace flow gives your wicker. Of course, I had to colorize the result to look like wicker too. :)
 Post subject: Re: Wicker
PostPosted: Fri May 10, 2013 7:01 am  (#2)
Really cool Lyle. I like the trick of using the Edge offset filter for the guilloche effect.
PostPosted: Fri May 10, 2013 7:33 am  (#3)
Appreciate the feedback David. :)
PostPosted: Fri May 10, 2013 8:06 am  (#4)
That is a very interesting effect Lyle...that petunia has travelled a lot of miles that you nursed back to health after holding out all winter.
nice job.
PostPosted: Fri May 10, 2013 8:10 am  (#5)
Nice that you remembered the history of my now passed petunia Molly. lolol
Thanks for the comments too. :)
 Post subject: Why not some more Wicker.
PostPosted: Fri May 10, 2013 8:43 am  (#6)
lol (at least I no longer have a marbles binge; ;) ). :)
ref: http://www.fontplay.com/freephotos/sixt ... 06-018.jpg
PostPosted: Fri May 10, 2013 9:36 am  (#7)
I should remember Lyle. I made that petunia into a sphere, and I did some other things with GMIC and too long ago to remember. I also made it into a pattern. poor little petunia without the onion patch.
PostPosted: Sat May 11, 2013 6:35 am  (#8)
WOW - I love that face.
PostPosted: Sat May 11, 2013 6:44 am  (#9)
lylejk: both of these really turned out beautiful - i like the face best too, just like erisian. it looks very expressive and it looks a bit more stylized than the flower and i like that.
PostPosted: Sat May 11, 2013 6:51 am  (#10)
I love the effect, it looks so cool!! :mrgreen: What kind of filter did you use? I assume it's not a standard GIMP filter?
PostPosted: Sat May 11, 2013 6:57 am  (#11)
BaukjeSpirit...Lyle used more than one filter on this. I think they are all from GMIC.
viewtopic.php?f=11&t=7192
PostPosted: Sat May 11, 2013 7:06 am  (#12)
Thanks molly! I'll have a look at GMIC ;)
PostPosted: Sat May 11, 2013 7:24 am  (#13)
You are welcome but when Lyle comes on line, I am sure he will be able to fill you in on what filters he used. He is the filter guy Y'all know. :teeth
PostPosted: Sat May 11, 2013 9:18 am  (#14)
G'MIC, but also used Wavelet Denoise Merge downand set to Ggrain Extract then Merge down, then along with Enhance Details Script-fu. Way too tired (just got off work; going to soon hit the sack) for any tut and probably won't be since even I have to keep my secrets (real excuse; way too lazy. lol). :)
Made a few edits. Not as tired as I was when I posted this earlier. :hehe
PostPosted: Sat May 11, 2013 3:10 pm  (#15)
Got up a little over an hour ago and then had to do some shopping for Dad. I noticed that I made an error in the flow Gram so I will soon correct it there anyway. :)
PostPosted: Sat May 11, 2013 8:03 pm  (#16)
Very cool effect, Lyle! :cool
PostPosted: Sun May 12, 2013 9:34 am  (#17)
gramg wrote:
http://www.gimpology.com/submission/view/fake_hdr_look_in_gimp/
Is this what you used at one point, Lyle...this is a very nice automatic script for effect.
I did the tutorial. It requires the dodge-burn script be installed...works good.
Cool info Gram, but I'm way too lazy to do all that work. lol
PostPosted: Sun May 12, 2013 7:58 pm  (#18)
O yes he is gram.
PostPosted: Mon May 13, 2013 4:43 pm  (#19)
O yes he is gram.
Molly knows me well. lolol
Poser/filter guy I am. The more I can coax the computer to do the work the better. ;)
PostPosted: Thu May 16, 2013 3:58 pm  (#20)
Sorry for the delay; just did another Wicker so linked this thread and saw your follow up. I either use Enhanced Details Script-fu or ACE (adaptive contrast enhancement) plugin or both depending on what I feel is needed Gram.
