It is currently Fri Nov 20, 2026 7:42 am
 Post subject: Bubbly Text
PostPosted: Sun Jun 16, 2013 9:22 am  (#1)
I used my bubble brush and stroke selection for the effect. :)
And a gradient layer for the water.
 Post subject: Re: Bubbly Text
PostPosted: Sun Jun 16, 2013 2:31 pm  (#2)
Yes! More bubbles!
PostPosted: Sun Jun 16, 2013 6:23 pm  (#3)
Well yeah, what's there not to like about bubbles?
PostPosted: Mon Jun 17, 2013 5:25 am  (#4)
If you can't pop em, they're pointless!
PostPosted: Mon Jun 17, 2013 9:33 am  (#5)
Ok, so these bubbles don't pop but so much cooler.
Nice work on the bubble text.
PostPosted: Mon Jun 17, 2013 9:53 am  (#6)
cool he4rty.
PostPosted: Mon Jun 17, 2013 1:53 pm  (#7)
Bubbles are cool no matter how you use them. In my honest opinion anyways. :)
PostPosted: Mon Jun 17, 2013 2:23 pm  (#8)
rod: :ditto like your bubble text, rod!
he4rty: nice find - this will have to be tested together with my godchildren :).
PostPosted: Mon Jun 17, 2013 3:13 pm  (#9)
Here's my take on Bubble Text...
Image :hehe
PostPosted: Mon Jun 17, 2013 6:08 pm  (#10)
gramg wrote:
Another great bubble design...I like the colors. How did you do yours, Wallace?
I used the new G'MIC filter 'Patterns > Pack sprites' to create the pattern inside the text.
I made a small grouping of 4 bubbles to use for the G'MiC filter to create the pattern with.
Once the pattern was inside the text, I duplicated it a few times and moved those layers around. Then used a saved text selection to clear the surrounding areas of the bubbles I didn't want. Then colored each layer pink and blue.
I also left a faint outline of the text on another layer, to help show more of the text shape.
The background was simple, I used a blue gradient that went form light blue to dark blue, blurred it a little then did a Colors > Posterize. Then sharpened it for more highlights. Finally, I rotated it clockwise and did a ripple, then rotated it back and cropped to size.
I also darkened the parts of background a little, that showed through the text , by using my saved text selection.
Once the entire image was complete I sharpened it a little more.
