It is currently Fri Nov 20, 2026 7:44 am
 Post subject: Cobblestone Dad
PostPosted: Tue Jul 02, 2013 9:40 pm  (#1)
Still a work in progress. :)
 Post subject: Re: Cobblestone Dad
PostPosted: Tue Jul 02, 2013 10:41 pm  (#2)
Very nice Lyle. :)
PostPosted: Tue Jul 02, 2013 11:31 pm  (#3)
lylejk: :jumpclap nice job!! is it still the pack sprites filter or did you achieve this some other way? really nice effect!
PostPosted: Tue Jul 02, 2013 11:37 pm  (#4)
Multiple passes of pack sprites with progressively resized source object. I first separated the light and dark to create 2 masks and then ran the procedure for each mask. I then copied the one result on top of the other. David did a good job of enforcing the mask which makes it easy. :)
