It is currently Fri Nov 20, 2026 8:49 am
 Post subject: Steampunk Embroidery
PostPosted: Sat Jul 06, 2013 5:57 am  (#1)
 Post subject: Re: Steampunk Embroidery
PostPosted: Sat Jul 06, 2013 6:06 am  (#2)
rod: wow, nice embroidery!! did you use a script for making this?
PostPosted: Sat Jul 06, 2013 6:26 am  (#3)
Yes , it is one i wrote myself. You can find it here.
http://gimpscripts.com/2013/04/embroidery-stitcher/
The filter works best with multi-colored images. :)
After you install this script into your scripts folder you will find it at Filters>Artistic>Embroidery Stitcher.
PostPosted: Sat Jul 06, 2013 8:34 am  (#4)
Very cool result Rod. I even recognize the gears. lolol
PostPosted: Sat Jul 06, 2013 9:48 am  (#5)
That looks awesome. Nice work.
PostPosted: Sat Jul 06, 2013 10:08 am  (#6)
Very cool, Rod. It looks so real.
PostPosted: Sat Jul 06, 2013 10:42 am  (#7)
great idea, Rod !
i've used te embroidery script in the past, its a nice effect
PostPosted: Sat Jul 06, 2013 10:42 am  (#8)
rod: thanks! i have the script already, but i haven't been able to get something really good looking with it yet - too much black, no matter what i start with :(. i'm gonna keep trying til i get something as nice as this!
PostPosted: Sun Jul 07, 2013 11:17 pm  (#9)
Nice effect Rod, and super easy to use!
Thx! :tyspin
bbbbbbbbbbbImage
PostPosted: Sun Jul 07, 2013 11:20 pm  (#10)
That is really cool
Is this the script that is best used with a denim or dark background?
I have used embroidery script on denim but not got such a great result.
PostPosted: Sun Jul 07, 2013 11:29 pm  (#11)
Awesome, Rod!
Very cool stuff!
PostPosted: Mon Jul 08, 2013 6:22 am  (#12)
Yes this script is basically hit and miss.
Some colors work real well and others may not. I find using shadows before running the script sometimes will work rather well. Inverting colors on an image before running the filter can also provide better results.
Here is text with a celtic art gradient (top to bottom) and a shadow with offset of 2, blur radius of 8, and opacity of about 75.Both shadow and text layers are merged together and the filter is then ran.
After the filter notice how the shadow takes on the colors of the gradient?
So you can see how using brighter colors with shadow increases better results. :)
Here i have selected the finished embroider layer and selected the black area with the color select tool.
Then i added a mask to this embroidered layer to make that area transparent. :)
I then created a new layer dropped it under the embroidered layer and filled that layer with a denim pattern.
This is zoomed 200% :bigthup You need now only touch up the embroidered layer and get rid of unwanted stitching areas.
And the finished piece after a bit more masking.
PostPosted: Mon Jul 08, 2013 7:44 am  (#13)
That is really cool, the result is very real
Congratulations
